i finally did this on the weekend
after rigorous testing i found that when your tyres are cold.. even if you take off slowly and then hit WOT, you still loose traction.. i have almost new tyres as well.. so im happy.. :banana:
I just did this today...
Honestly cant feel any diffrence on my R34 GTT auto...weird.
Im going to get it dynoed soon so will hav it dynoed with and without the mod, i might be suprised.
One sign tho to see if the solinoid is actaully earthing or not with the wire you used-
Start car, tap the wire on then off the bolt or bracket your fastning it to, the solinoid will make a slight "clicking" noise.
All i did was splice into the black wire and attach a complete new wire coming off the spliced bit onto an earth..
So the black wire still goes into the plug aswell but is earthed BEFORE it goes into the plug.
Ok i wanted to do this mod but wasnt too keen on cutting the wire. Well i did it today, took the car for a drive at 6pm and the boost felt more responsive.
I washed the car and took ot for another drive at 9pm, i was in 2nd gear and the car suddenly stopped boosting and kind of felt like it jumped. This also happend in 3rd gear and kept happening for the next 5 mins or so till i got the car home.
What would the cause of this be? Is it wrecking my car? I will see if its the same tomorrow and probably put it back to normal (not too happy after getting a taste of that whole extra 2 psi).
Thanks so much for the help if it wasnt for you guys i would be getting ripped off by a mechanic and not knowing how to or what to do to modify my skyline. Once again thanks guys
Edited by WET-25T
I'm willing to be you've got water in your coilpacks from washing the car if it was OK before and no good after. DId you wash your engine bay?
If not, it could be a miss related to plugs or coilpacks. More boost means you might need to close up the gap on your spark plugs to 0.8mm if your coilpacks are a bit old. Or just grab some new coils.
was the motor cold?
on my 33 i have bypassed the solenoid altogether.
mine never had the top tube going to the solenoid ???
what i done was unplug the solenoid all together and run a tube from the intercooler piping to the actuator.
hits 7psi by about 2200 rpm with a 3"split dump pipe
Hey, i wont boost unless my engine is fully warmed up and no i didnt wash the engine bay. Its strange bcoz it hasnt happen since that night. Anyways i put my boost gauge in today and it was showing 9psi. So i disconnected the new earth i put in for the high boost and took it for another drive.
It was showing 7psi for low boost then it goes to 9psi for high boost. The only mods that it has is a turbo timer, the boost gauge i just put in and a pod filter. No other performace mods that im aware of what so ever. Is this normal for 7psi low instead of 5psi and 9psi high instead of 7psi? And is 9psi safe or should i just keep it on the 2 boost setting?
Also i didnt cut right through the wire i made it into a t-piece for the hight boost.
Thanks and thanks for the fast reply Duncan
Edited by WET-25T
well given that it went away I still bet you got the coils wet somehow, do you have a vented bonnet?
anyway - re standard boost, I have done this mod in my stagea, it has a unifilter panel filter and radiator air guide are only mods, but it spikes to about 8.8-9psi sometimes. I think as you free up the intake and exhaust standard boost increases a little.
9psi is fine as long as the fuel system is healthy (injectors and fuel pump) with the standard ecu. just keep an ear out for any pinging as it comes onto boost (mine pings a little and I'm assuming its because the fuel pump is on the way out).
Well ur right in the sense that i de greased my engine about 2 weeks ago or so, not sure if the would still b water in it and it was fine straight after i did it. In 2500 k's which will b at 70,000 kms i will do a FULL service like everything. Thanks again
Just did this mod to my R34 GTT (tiptronic) and made a noticable difference! Power felt alot stronger down low.
I was driven to do it because I had been getting the missfire at 5000rpm when the boost levels changed. My engine is stock except for an apexi power intake. I only started getting the missfire since I installed that.
I skimmed through most of the 22 pages in this thread and saw a few people saying to run it on a switch - so you can switch it back for highway runs. Though I don't understand why? On the highway my boost guage sits at around -300mmhg (about half way in the negative) and after the mod continues to do so unchanged.
So as far as I can understand this mod shouldn't make any difference to fuel usage except the times when you're on boost below 5000rpm? (at which point it rose to the higher boost level anyway?) Am I wrong? :O
Edited by R34mac
  • 5 weeks later...
So as far as I can understand this mod shouldn't make any difference to fuel usage except the times when you're on boost below 5000rpm? (at which point it rose to the higher boost level anyway?) Am I wrong? :D
I reckon the switch would be a good idea, so you can keep it off boost while the engine is still cold... once she's warmed up - switch over to the modded boost levels. Or for wet/greasy roads (like today)... it'd just be good to have to option to change it quickly and easy IMO.
Cheers
i havent made changes to the solenoide wire, it looks to be standard.
Although my stagea makes a lil bit under 9psi on full boost, but this is showing on the guage before 3000rpm. The car does have a MiNes ECU would this possibly ignore the 'half boost' mode? It still feels like it pulls harder from 4500rpm, but still makes same boost level.
Car also a 3 inch exh. from the turbo.
Any ideas would be great.
Thanks.
Yeah, rain adds 25kw - so i flick high boost on and then it feels like it's added 50kw :)
Apologies if this question has already been answered. 420 odd posts is too many to go through.
Wondering if you need to make this solenoid mod if you have installed manual boost control i.e. a T piece or bleed valve???
At the beginning of the thread it says if you have aftermarket boost control that you no longer need to do the mod. But it seems as tho if you just put a T piece or bleed valve in-line, the ecu is still controlling the operation of the solenoid and so would you be running say 9psi to 4500 rpm then 11psi til redline?????
thanks
Edited by e_Dog
i was bored and decided to do this mod, took 10 mins. took the car for a wrap and noticed the stock boost gauge needle alittle bit higher then the line under 7. which is around 8ish psi?
felt good down low and pulled up harder. 3" dump/front pipe hopefuly going on this weekend :)
Anyone got an answer.
Do you have to do this mod still if you have an aftermarket MANUAL boost controller??
i.e. does the manual boost controller require removing the stock solenoid.....or is the stock solenoid still in operation with a manual boost controller????
did this mod other day couldnt relle fell much difference... tryed tapping my ground but couldnt hear much coz of engin noise... i cut the black wire, the one that goes back down that tube casing got grounded. the other end just got taped of. is this correct? cheers
well I don't know about solenoid operation with an aftermarket boost controller but in the first post it says:
Background:
As you all know the standard R33 RB25DET boost solenoid (value controller) is 5psi until rpm is greater than 4500rpm and then its 7-8psi. Continue reading if you wish to always be in high mode (7-8psi). If you have an aftermarket boost controller then you can stop reading now.
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
