Hi guys
1997 Nissan Skyline R33 S2
Im getting a ticking sound that seems to come from the front right wheel
- alignment done
- tie rod ends replaced
- suspension check - all good , nothing loose except for front right wheel having slightly to much camber
- jacked car up, span wheel - no noise - nothing in way
- rechecked if any cords or anything else in way , all tucked away perfectly.
- doesn't happen when turning
- no difference when breaking
- no difference whether accelerating/decelerating
- noticable from 20km.h to 80km/h - after that sound stops
- car drives fine , steers fine etc..
This is driving me crazy, any suggestions? Could it be cv joints , bearings , stone caught in caliper etc? Anyone been through this before after checking what was listed above?
https://www.sau.com.au/forums/topic/431204-annoying-ticking-sound-please-help/
Your car doesnt have cv joints at the front so you can eliminate that off your list
Swap front right tyre for rear left
See if that changes anything
good idea
Check under guard liners? Or try removing guard liners and driving the car?
removed guard liners
What Rims?
I've got BBS RS and my middle plate that covers the lug nuts if it twists abit it makes noises.
Just a thought
cant remember brand of rim , not brand name - also has no centre cap lol
thanks for the suggestions guys , im going to have to take it to a suspension shop and see what the hell this is.
Glad you sorted it. :thumbsup:
was that "Tyres Plus"? Plus what? Headaches... :laugh:
I had tyres rotated at "Tyres and More". More because they didn't tighten the nut on my center caps and I lost one. Had to buy another. :(
Yes tyres plus Menai - dont like to bash shops but when i went there the first , they backed my exhaust onto the lift , causing the boss to start screaming at his apprentice and punching some tyres laying around - while im sitting in the car hopping my exhaust is okay,
The second time I went there, they did an alignment, car was still pulling to the left horribly , and took over 45 min to do it.
Just felt like they didn't want me there , didn't like the arrogance....but was okay with that since i assumed the work was top notch, Apparently it isn't..
Oh well ,that's what I get for taking my car anywhere other then Unique Automotive.
Guest
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
