Hey everyone,
I'm in need of some advice for buying a stagea.. Mods please delete or move if not allowed or in wrong place..
I need help because I honestly don't know much about cars and this is going to be my first car with forced induction, so I'm a bit worried..
I've narrowed my selection down to 2 cars both with different mods and Kms.
Option 1
2000 Nissan Stagea WGNC34 260RS
80,000kms
$19,000
Performance/Reliability Modifications:
- Apexi power FC (tuned by EFI performance to 345hp on 16psi
- Denso 700cc injectors
- JJR adjustable cam gears
- Deatschwerks fuel pump rewired with full voltage
- Brembo brakes with ungraded DBA 4000 slotted rotors and bendix pads
- BC br coilovers (height and damp adjustable)
- Splitfire coils, new plugs and o2 sensor
- Custom mandrel bent cat back with resonator into 3’’ highflow oval muffler with twin tips
- Decat and a Cataco highflow cat
- Xforce split dump pipes
- JJR 2.5-3’’ front pipe
- Nismo air flow meters
- Greddy profec B spec 2 boost controller (low – 10 psi high – 16 psi)
- Aluminium radiator
- Intake and ACC gaskets replaced
- Blue Samco radiator hoses
- New century battery
- Starter motor rebuilt
- Nismo FPR
- Radiator fan replaced
- alarm and immobilizer
- Tinted windows
- Clear side indicators
- Mearcat double gauge pod holder with fuel pressure, oil temp, and air/fuel
- Nismo gear shifter and floor mats
- Bonnet gas struts
- Genunie Greddy clear cam gear cover
- Blitz turbo timer
- JVC cd/usb head unit with remote
- Blue LEDs in zircon
- Xenon headlights with height adjustment
- Auto dimming rear vision mirror
Option 2
1997 Nissan Stagea WGNC34 Autech 260RS
160,000kms
$15,000
Genuine autech 260rs with fully rebuilt motor. The car makes 330kw at the rear wheels at 20 psi.
Receipts for the engine rebuild are available. Work was done by Advan performance in Auburn.
Modifications include
-hks gtss turbos
-cp pistons
-eagle rods
- sard injectors
- hks fuel rail
- os giken twin plate heavy duty clutch
- reconditioned gearbox
- mines front pipes
- x force exhaust
- link ecu
- greddy boost controller
- Dba 5000 series brakes
- bc coil overs
- r34 gtr rims (18x9) in black
- tomei pon cams
So, I'm mainly just looking at how reliable they are, haven't had a chance to look at the cars yet, as I'm a good 1000kms away.
Im leaning towards the 1997 model but is a Stagea with those sort of kms reliable..?
Any help is greatly appreciated,
Thanks in advance, Chris.
Edited by MaccaD2191
https://www.sau.com.au/forums/topic/446507-need-buying-advice/
the first thing i would let you know on is that almost every import car in Australia has a would back odometer, so maybe get that checked on both http://japaneseodometercheck.com/ these guys offer a service where they will check for a more accurate odometer reading.
Any reason why you're limiting yourself to the Autech? Id recommend finding a very clean manual C34 AWD and then spending the cash you saved on doing thorough repairs and maintenance. If its going to be a daily driven practical vehicle, the RB25 with basic mods like exhaust and reconditioned/high flowed turbo is a good pick.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
