A decent thermo setup is probably the best thing for a track car. For the following reasons;
  1. When you are right up the car, the car is generally moving quickly, thus getting decent natural air flow through the radiator. Thermo fans probably won't need to be running, and you would benefit from not having the load of a clutch fan on the engine.
  2. When you have been right up it but have had to slow down (yellow flag, going into the pits with a flat, broken suspension, whatever) then a clutch fan doesn't work it's best at lower revs and the thermos will work as well as they ever do - even if you've had to shut the engine down hot, the thermos will still allow a bit of heat to get dispersed. Not a bad thing.
For a road car I am strongly in favour of the original fan and the original clutch, preferably new ones. And when I say "original clutch", I mean the original type from Nissan. The Davies Craig etc aftermarket ones all seem to suck balls. I have been through several trying to get one that doesn't lock up at too low a temperature and make my car sound like a Patrol in traffic.
Edited by GTSBoy
  • Like 2
This is a neat replacement made by GKtech, I've got one in my R33 and it's definitely improved cooling efficiency.
http://www.gktech.com/index.php/s13-s14-s15-replacement-engine-fan-60-more-air-flow.html
You'll need to get the adapter too, as they were designed to bolt up to SRs.
http://www.gktech.com/index.php/sr-to-rb-clutch-fan-adapter.html
I ran a thermo in my 32 for a short while, and had problems keeping the engine cool at any time, but particularly on the track. (Mild day (25ish) at Winton, 1 lap, engine boiling. same day, Highway cruise, slight uphill, thermo cuts in.)
I put the standard clutch fan back on, and haven't hade a problem since. (Mild day QR, 4 laps, engine slightly over thermostat temp.)
I would strongly recommend staying clutch, otherwise if you go thermo, spend a lot of effort in making sure air goes through the radiator.
keep the standard clutch fan. upgrade the radiator. stock core is 16mm thick, put a 42mm core in and it will make a big difference to cooling ability.
make sure you retain the factory fan shroud. it's there for a reason.
^^ +1 for fan shroud, regardless of whether you're using a mechanical or electric.
The aim is to achieve airflow through the whole core to promote heat transfer. You will find the OEM "splash tray": running back from the lower radiator support is an important cooling element so make sure it is retained.
Off topic, but is that black 32 the one you are putting on the track? Ride height looks like it might give some suspension travel and geometry issues unless you've done a LOT of work in that area.
Interesting, because I've heard more negative reports on those things on RB than good.
  • Like 1
Is that so? I've been considering buying the adapter plate and putting it on my RB for a little while now as I've got the fan sitting on the side from when i had an S13. The fan went well on my SR and I've nothing but praise from people running clutch fans on their SR's at QLD Drift Matsuri, they swear by it, i'd assume an RB would have a similar result? all it does it pull air through a radiator better than the stock design, well at least they claim to.
The only people I've heard bash the fan are those who think it will lower the operating temperature, and are also using the stock temp gauge to "measure" their "results" - both of which render their "research" useless as they clearly have no idea what they're talking about.. lol
Has anyone here had a bad experience with it on the RB? :mellow:
They're actually not an upgrade in terms of air flow or pulling power compared to an RB fan - especially the later RB fans. I think the GKTech fan is designed to pull less air and unload the engine as it is really aimed at the drift market.
Not bashing that fan, just pointing out that it might not be the best choice for an RB.
  • 5 years later...
Motor is is a rb25,My clutch fan is hitting the cooler pipe and cracked it! Dose anyone know if the rb26 clutch  fan will be a direct fit into the 25 shroud? as iv heard the blades are shorter so less chances it hitting. Cheers
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
