R32 Gts+t Daily/street
If you go AWD, then no sideways fun. But a 26 swapped GTS4 sounds good... Have both?
way i see it
AWD good for Grip and potentially safer/faster around track and during "spirited" driving. But worse for Skids and U-turns
  • 3 weeks later...
Unfortunately i was unable to look any further into the GTS4. but here is a potatocam drive by to enjoy
I plan to film a better clip at a laterdate.
  • Like 3
  • 3 weeks later...
In an effort to reduce the laggy feel i went and bought a 4.36 ratio diff to replace my 4.08. the whole time i thought i had a Nismo GT 2 way but as it turn out it was a 1.5way hard to tell until i looked at it side by side with the new 4.36 nismo 2 way i bought. the new diff i bought is a 5 bolts vs the 6 bolt i had before. so nice upgrade there
i also wanted to fix the excessive front camber i have which was -3.8'. I did this by buying some superpro adjustable poly bushes. the old ones literally smelt like poo when we pushed them out haha
got under the car to swap out the diff and noticed this
subframe had to come out to fix this and at the same time i noticed my exhaust had done this to the rear bar
also the bushes were well buggered. I had been using metal subframe lock collars but it really was a bandaid solution.
burning out the old bushes.
ended up with whiteline poly bushes. i toyed with the idea of metal subframe risers but the whitelines came up for a good deal and it is still a street car. however even with a press the back two bushes were a pain to do and ended up up having to make this contraption up to get them in. Made from two Daihatsu strut tops drilled out and a pulley puller with a breaker bar and a jack pole
while it was out i scrubbed up and painted the subframe and arms. looked nicer imo and protects from rust
  • Like 1
  • 5 weeks later...
Booked a track day and was able to finally to stretch the cars legs with the new tune.
Bought a new set of wheels for track use, 17x9 +25 Rays Volk TE Fortresst. think old TE37 + AVS model 6 for the style and fitted up some brand new Hankook RS3 tyres to them in a 255/40/17. Got some help fitting them up :thumbsup:
The wheel and tyre combo was bigger in practice than in theory. In theory they should have been +5mm each side fro tyre and -3 offset on the rim resulting in +2mm on the outside edge and 8mm on inside effective when compared to my 17x9 +22 AVS T7 with 245/40/17 but the Hankook tyres were bigger resulting in some rub. haha
sorted that out then on to wiring. perfect thing to be doing at midnight the night before track day.
Got out to Mallala nice and early and unpacked the car
13047788_908048009292543_892282480551732
out on track
13055711_908046672626010_833905046696944
13029710_1046899718716955_51798638418556
ended the day with a jerrycan rescue for one of my mates also driving at the day.
Short video of one of my laps. My phone ran out of storage before the best lap of the day but i managed improved a few seconds on my best lap last visit with a 1:26.8. Overall it was a great day with only a few minor issues but i drove there, did the track day. then drove home so i call that a win.
Edited by CRSKmD
hey mate
what did the new diff set you back? ditto with the rims?
got lucky $750 for the diff freshly inspected and setup and $850 for the set of rims with stuffed tyres
  • 2 months later...
not much new but i did have my car used for a photoshoot recently. So have some pictures. a few from my iphone and some from the photographer (watermarked ones).
heaps more on their site if people are interested
13254791_1069114493162144_56894265375088
13323612_1080829525323974_46009261908240
  • Like 3
  • 2 months later...
Small update:
R34 LCA with adjustable lock stops to get my turning circle back as R34 LCA stock lock stops  got in the way long before the rack maxxed out.
end result was ~1m my turning circle.
TRUST Turbo heatshield to try and keep some heat off vac lines that melted last track day ...and for some bling haha
13662526_10155176736019896_372109798_o_z
13647235_10155176735154896_849870771_o_z
also picked up a hand held gimbal to muck around with and shot a bit of driveway test footage below
  • Like 2
  • 3 weeks later...
Signed up for another grip day at Mallala.
arrived bright and early and got the car unpacked and setup
Convinced my mate to come out in his RWD manual stagea.
mid turn in, Easy to see the tyres cross section here haha
pitwall ft. "genuine" (fake) GTR grill doing its thing... i call it dynamic aero
nice deserve range of cars in my session
All in all a great day. Smashed my old PB and had a great time
On 10/1/2016 at 7:49 PM, Tom101 said:
Looks really clean! shame about the crash
Cheers mate, it was a kind of a blessing in disguise as without it i likely wouldn't have have the "bugger it just track it" attitude.
Prior to the crash it may have ended up getting a full body refresh and being super clean but the trade off would have been more cautious use and less/no track time
    • Personally, i'd be dropping the extra $400 for the Pro series. I believe (at least during their original conception) they were based off the Blue series but have evolved with apparent new valving tech etc etc.  The BC's were super harsh ride wise, felt like the road was covered in potholes almost (this with damping at softest), but they did feel a bit more pointy initially through corners, i felt like there was considerably more understeer at turn in on tighter radius corners (but this is not really a like or like, considering the difference in wheel size, tyre choice, track temp etc etc)
    • Facts but it's okay I've ordered a new ignitor based on GTSBoy's confidence. In the meantime I did the ole jiggle tap on the maf connector with no change. Seems like the warmer it gets outside the worse the issues get. Hoping it's the ignitor. Also going to pick up some carb cleaner and try to get that iacv cleaned out real good. I'll report back once I've gathered more data. I really appreciate the feedback though guys keep it coming. Trying to learn everything I can about this car want to keep this thing for a long time.
    • Unfortunately this is a bit like arguing if you prefer blondes or brunettes....you will get people who strongly hold either view. My observation is I have had good results racing on MCA golds (spring led) but personally find Gary's approach of lighter springs and heavier bars is more predictable over mixed or rough surfaces like in rally (or an Australian road)
    • Yeah, they mentioned that its not worth upgrading from the stock sway bar due to how their coilovers are set up.  Still learning more about the suspension etc, but with Garys approach of lower spring rates and controlling roll with bars and obviously improved dampers, wouldnt that be like softer ride and more roll but with the sway bar, it keeps the roll to a minimum/lower amount? Where as MCA's approach of stronger springs, and dampers adjusted for the springs, wouldnt that be a harder ride (against bumps, going straight etc) and less roll, and the stock sway bar does its thing but the coilovers does the majority of the work? Its a daily so im in favor of a softer ride while normally driving but keeping the roll to a minimum while turning etc. Or am I getting my idea of suspension completely wrong?   I was looking at the Pro Comfort, it has the price hike of it being the MCA Pro series ( extra $400, total $2490 ). Ive read people saying the blue/red/gold series(and the blues being more favorable from the past threads) but what would those be nowadays?  What was the drive difference between the BC golds and the MCA Blues you got?
    • more then likely but not very practical for a street car
