Hiya all :cheers:
If you've seen the "Pushing a mostly stock R33" you'd know where this question comes from.
Anyway, I have an R33 Spec2 and would like to run ~2psi more boost and hold it properly. At the moment I have a GFB bleed valve controlling the boost level, but it bleeds off quite quickly after peak boost is reached - though I know that the Rb20DET turbos seem to run a couple psi higher boost than the RB25DET ones, so theoretically if I used the same boost control they do I should get similar boost behaviour - so wouldn't really need to rely on a bleed valve.
I can get an R32 RB20DET turbo for free, does anyone know if I can use the actuator/actuator spring with the RB25DET turbo? Any thing I should know?
Cheers in advance!
Dan.
https://www.sau.com.au/forums/topic/45390-r32-wastegate-actuator-on-r33-turbo/
Can you get me an actuator free too??  Im willing too experiment.
Yes they are a straight bolt on.
Haha - I'd love to :) One of my friends blew his R32 RB20DET turbo recently, running ~18psi through it :headspin: This is how I am getting one so FREE, I just happened to think of it when I was pondering how to alter my boost actuation.
How long have you been running 13psi through your stock turbo??? Thats pretty up there...
12-13psi for a good 8 months or more and it gets its fair share of caining.
Im ringing around now to find a R32 actuator, apparently you can bend the rod to put more pressure on the spring.
Yeah, I know about that way around it - but I would rather not :)
  • 4 weeks later...
Update - I have an R32 GTSt actuator on my car now :cheers:
On "stock boost" I am running 10-11psi, seems to come on stronger - feels particularly meaty around 4000-4500rpm. I find it hard to tell if its any better up top, there is definately a LITTLE drop off in the high revs. It will be going on the dyno on the 21st August for a boost and power read out, to see what the difference (if any) really is :)
I bought a HKS actuator and yes still notice some drop off, not as severe though.
Ahh ok - so the R32 actuator is a good (price wise) alternative :cheers: The ultimate would be getting an electronic boost controller then, but the better actuator is going to make its life easier... when I eventually get that sorted.
So you are still getting drop off below 10.9psi?
10.9psi for myself is the stock boost level for the rb20det actuator.
To hold more boost I elongated the actuator bracket holes and pulled the wastegate towards the front of the engine bay.
This preloads the actuator spring and reduces the total travel of the actuator, effectively stopping the wastegate from opening as much.
The result.... boost comes on harder and will hold anywhere up to 1.1bar without a bleeder, if adjusted too much it will get boost creep and make 1.1+bar.
This setup works best with a bleeder to help bring boost up hard in the mid.
The RB20DET's are pretty tough and will hit a fuel cut before you blow the turbo (well mine does at just over 1.1bar). So You drive along with the spanner adjusting. Or you can do it on the Dyno which is much much safer.
I've had it running 1.1bar like this with a bleeder for the last 6 months.
Prior to this setup I was running a Blitz SBC-iD and 1.1bar.
Which one works better and holds boost more consistently?
The bodge job with the bleeder, the EBC held boost well but driving up a hill on load at around 3000rpm and putting the foot down would see a boost spike.
Its cheap.. A Free MOD!.
For the R33 people, I think the best thing to do is get one of these R32 actuators on your car, and then mod the factory bleed solinoid so it's on all the time (there's a DIY thread about doing this).
So you should get the (new) stock boost of 10psi with the R32 actuator, and have the factory solinoid bleeding off to bring it up by 2psi = 12psi :cheers:
Total cost would be just the R32 actuator, and you'd have the benefits of everything looking totally stock standard :)
J
  • 6 months later...
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
