Club Permit Info
Tony Olsson
 Share
To be eligible to get a club permit you must be a financial member of a VicRoads approved vehicle club or association.
For us to issue you a club permit, you must be a member of SAU Vic.
After joining SAU VIC there is a 3 month waiting period and at least one event before being eligible to apply for a club permit through SAU VIC
*This is at the clubs discretion as you may have been a previous member, or attended events not as a member. Long standing forum members may also be exempt for the 3 month wait.
We also ask that you attend at least 2 club events a year.
A club event is defined as –
Any SAU Vic Motorsport event
SAU Vic Show & Shine
Any ‘Members Only’ events
SAU Vic Monthly Meets
To join SAU Vic visit our website for more info - http://www.sauvic.com.au/how-to-join or come see us in person at one of the clubs many events.
Or visit the VicRoads website - https://www.vicroads.vic.gov.au/registration/limited-use-permits/club-permit-scheme
If you have any other questions feel free to send us an email at [email protected]
or come talk to us at one of our events, we are more than happy to chat :)
 Share
    • Timing map only tells part of the story, I've seen a few cars where the CAS has been adjusted so you might see 12 at the ECU but at the motor you could be seeing 8 kind of thing. A S15 I converted from PowerFC to Nistune had just that, CAS was turned back to have less timing than the ignition map itself lol... "Choonered".
    • But your running 1.6 bar of boost, is it still 12 degrees of timing at 1.6 bar of boost? Also, is there e85 fuel at the petrol stations in Dubai?
    • swaybar swaybar swaybar swaybar swaybar anyway OP, what is currently in your car, are they factory shocks and sway bar? Any sign anything else has been changed under there over the years? And as Murray said....what are effect you looking to change
    • Congratulations on your find  Did you mean it has 6k miles or was that a typo? Firstly, keep in mind some movement of the shifter is normal...it is a long rod hanging out of a box bolted to the engine. Having said that there are 2 next places to look: 1. Transmission and engine mounts. If these are worn or broken the shifter will move around more. They are reasonably easy to source and replace on a hoist, and possible but uncomfortable to replace car stands 2. On the bottom of the shifter there is a nylon cup that sits over shifter's ball end. If this is worn or broken the shifter will move around more than it should (but will still shift OK). That is a cheap part and requires removal of centre console, rubber shifter hole covers and a circlip in the gearbox shifter hole to remove the shifter. Re maintenance, as with any new import you should change all the fluids including transmission when you get it; never trust the seller and previous owners to have done the right thing. I am pretty sure R34 GTT is the same as earlier big box transmissions, so use any good quality GL4 75w90 trans fluid if it is shifting well (if it is hard to shift due to synchro wear, redline shockproof lightweight will keep it alive a bit longer before rebuild is required)
