If you need Nistune hook ups you know who to ask :)
And congrats on finding a new job, I should start looking myself. Already have had 2x weeks of unemployment, don't think I like it lol.
lol yes I know
As if I would buy all that fruit for the bottom end and head then run it on a Nistune
I might cheap out on the turbo yet, but I won't cheap out on management.
Nistune is very capable, full ethanol blending, boost by ethanol concentration. Compensation cranking fuel tables by ethanol concentration.
There's a critical issue though.
Nobody here wants to tune it. Getting the Silvia done was a bit of a pain last time, and I can't say I was impressed with the result (which may say more for who tuned it). If I can't get good results with one locally, there's no point.
Would rather go with what my tuner likes and recommends.
  • Like 1
You're kidding me?
You mean I shouldn't just assume everything I read here is fact, do my own research, and come up with my own conclusions anyway?
Because I have certainly never done that...
I'm not sure what I'll do about the backwards engine just yet, but I'm sure there's a box to fix it.
  • Like 1
When Nissan parts don't fit too well, borrow some inferior Mitsubishi parts :)
(Mitsubishi makes those awful CAS units for the RBs, which to be honest are gaids)
ignore the red hoses for now, they were from my temporary and last minute PS cooler which somehow became a permanent fixture.
  • Like 1
Lines all nipped up, all fluids filled in motor, bled coolant system without engine running (will bleed it again once she starts up).
Fitted inconel studs and locking nuts to manifold/turbo as well.
Looks like it's ready for fab soon!
  • Like 3
1 hour ago, WantGTR said:
Can you hurry up and turn the key ffs.
Here's a shot just then, it's a bit dark.
I assume car won't dose as mad as it did with the Hypergear ATR45SAT 6+6 VL ulleh spec cast compressor, but fast is best.
  • Like 1
Wtf Is this shit??
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
