• Welcome to SAU Community
    Welcome to SAU Community, like most online communities you must register to view or post in our community, but don't worry this is a simple free process that requires minimal information for you to signup. Be apart of SAU Community by signing in or creating an account.
    • Start new topics and reply to others
    • Subscribe to topics and forums to get email updates
    • Get your own profile page, build reputation and make new friends
    • Send personal messages to other members.
    • See fewer ads!
    Consider joining our newsletter for the latest content updates
    Click here to register
Motul_
Motul World Motorsports News - Asian Le Mans, Andros Trophy, French 4WD Trophy Win
1 post in this topic
Motul%20World%20Motorsports%20News%20%20
WHERE TO BUY: Motul Australia – Dealer Locator
Looking for the right oil for your car? Easy! Go to www.findmyoil.com.au*
*Findmyoil.com.au is for OEM recommendations only. For modified vehicles, consult your tuner or contact Motul.
Stay connected with
Motul Australia – Cars Facebook Page
Motul Australia Website
Motul on YouTube
We’re here to help!
Can’t find an authorised reseller near you? Any questions on queries? Let the Motul team know. Send us a PM!
If you have any questions about any of our products please feel free to get in contact with us.
Share this post
Link to post
    • By Motul_
      Stay connected with
      – Motul Australia – Cars Facebook Page
      – Motul Australia Website
      – Motul on YouTube
      We’re here to help!
    • By Motul_
      Needless to say, the Nissan 200SX S15 has developed a massive following since it was first released back in 1999 here in Australia. It has all the right ingredients for an unbelievably fun sports car. Two-door coupe? Check. Sharp styling? Check. Lightweight? Check. Turbocharged power? Check. Rear-wheel drive? You better believe it. Its turbocharged SR20 powerplant put out a respectable 147kW straight out of the box and thanks to an abundance of aftermarket support, it has the potential to make a whole lot more. There’s no questioning the popularity that the S15 has amassed, still heavily sought out after by car enthusiasts more than 16 years after its initial release.
      Motul offers and recommends the following oils for your Nissan 200SX S15, which can also be found by visiting Motul’s www.FindMyOil.com.au car fluid search engine.
      CAR SEARCH
      ENGINE OIL
      MANUAL TRANSMISSION FLUID
      AUTOMATIC TRANSMISSION FLUID
      DIFFERENTIAL
      POWER STEERING
      Above is just a sample of what’s found on the website. Knowing what lubricant to use in any model you have is easy. Just go to www.FindMyOil.com.au and either type in the make and model into the quick search bar or search using the drill down function.
      WHERE TO BUY: Motul Australia - Dealer Locator
      Stay connected with
      - Motul Australia – Cars Facebook Page
      - Motul Australia Website
      - Motul on YouTube
      We’re here to help!
    • By Motul_
      Motul - Inugel Expert Ultra
      Motul Inugel Expert Ultra is a concentrated coolant formula utilising hybrid technology and offering protection down to -54°C/-64°F. Motul Inugel Expert Ultra is based on monoethyleneglycol and thus can be mixed with other monoethyleneglycol-based coolants.
      Motul Inugel Expert Ultra is recommended for use across all cooling systems. Everything ranging from passenger cars, heavy-duty commercial vehicles, construction and agricultural vehicles and stationary engines.
      As you should expect from a quality coolant, Motul Inugel Expert Ultra offers outstanding protection for the cooling system from freezing and metal components from corrosion. It also provides an excellent thermal exchange which in turn improves engine cooling efficiency. Thanks to the silicates and organic acids present in Motul Inugel Expert Ultra, anti-corrosion properties remain even as the coolant ages.
      Due to the fact that Motul Inugel Expert is a concentrated coolant product, it is important to dilute before use, ideally using soft water. Refer to your vehicle owner’s manual for the required mixing ratio to suit your vehicle’s cooling system. To maintain anti-corrosion properties, do not dilute below 33%.
      Stay connected with
      – Motul on YouTube
      We’re here to help!
    • By Motul_
      Motul - Gear 300 LS 75W-90 gearbox & differential fluid
      Much like your engine, your gearbox also needs regular fluid changes to keep it performing in top-notch condition. A 100 per cent synthetic ester-based lubricant, Motul Gear 300 LS 75W90 has been designed specifically for high performance and racing applications.
      Motul Gear 300 LS 75W90 can be used in everything from synchronised or non-synchronised gearboxes, gearbox/differential, transfer gearboxes and hypoid differentials with limited slip systems operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speeds.
      Developed to withstand extreme pressures, Motul Gear 300 LS provides efficient anti-wear protection, better resistance at high temperature and an overall longer service life. It also contains a special friction modifier that works to help prevent noisy or dragging in limited slip differentials. With a high level of lubricating power, friction and wear is decreased and you can expect smoother, easier gear shifting even in colder conditions. Motul Gear 300 LS is suitable for any type of seal and any type of material used in gearbox and limited slip differential design.
      Motul Gear 300 LS is suitable for use in cars requiring 75W 90 gearbox or differential fluid that utilise limited slip differentials either integrated or non-integrated in the gearbox. It is also suitable for use across a wide range of motorsport applications from track to rally.
      Stay connected with
      – Motul on YouTube
      We’re here to help!
    • By Motul_
      Motul World Motorsports News - Super GT Twin Ring Motegi, Endurance Proto Challenge, Rome 6 Hours
      Stay connected with
      – Motul on YouTube
      We’re here to help!
