Rb25, Rb26/30 part out
Due to financial reasons unfortunately i have to sell all my car parts. Spent way too much money buying all these parts and never even started building my motor yet so hoping to get some $$ back now.
1. Completely rebuilt rb26 head built by Pro-Built Engine Reconditioning Gold Coast.
New shims
K line valve guides
All cold side and sensors $2500
2. Rb30 series 2 block in good condition $100
3. Rb25 greddy copy plenum with all the vacuum lines and bolts $200
4. RB30DET (DOHC) Rebuild Kit with Ross Racing Forged Pistons 9.0:1
SPOOL Forged H Beam Conrods
Ross Forged Pistons (Rings, Pins and Locks Included)
Cometic MLS Head Gasket
ACL Race Series Main Bearings
ACL Race Series Big End Bearings
$2000
5. Rb26 forward facing plenum by Otaku racing
Billet CNC Aluminium Manifold (Suit RB26, RB26DETT)
90mm Throttle Body
Dual Feed Fuel Rail (Suit Top Feed 14mm Injectors)
IACV Port & Vac Line Ports
Water Line Kit
$950
6. Arp head studs for rb30/25/26
$200
7. Gates timing belt for rb30/26 and rb30/25
$100
8. Rb26 N1 oil pump
$250
9. Rb30 waterpump
$80
10. T78-33 T4 turbo, high flowed by Turbotech in Perth and newer installed after that.
$1300
11. Rb26 Trust/greddy T4 manifold
$400
12. Rb25 or z32 afm?? Brand new Chinaspec $25
13. R33 strut bar $100
14. R33 24mm heavy duty front sway bar. $250
I'm in Darwin but all parts can be delivered Australia wide on buyers expense. Best way to contact me text or ring 04 74 120 500.
Photos are in random order.
20170212_151005.jpeg20170212_150824.jpeg20170212_150839.jpeg20170212_150802.jpeg20170212_150713.jpeg20170212_150548.jpeg20170212_150532.jpeg20170212_150440.jpeg20170212_150405.jpeg20170212_150313.jpeg20170212_150150.jpeg20170212_150156.jpeg20170212_150014.jpeg20170212_145949.jpeg20170212_145942.jpeg20170212_145732.jpeg20170212_145612.jpeg20170212_145430.jpeg20170212_145313.jpeg20170212_145323.jpeg20170212_145229.jpeg
  • 3 weeks later...
  • 3 weeks later...
Thank you Khezz, was pleasure dealing with you mate!
Items that are sold so far:
*4. RB30DET (DOHC) Rebuild Kit with Ross Racing Forged Pistons 9.0:1
*6. Arp head studs
*7. Gates timing belt
*9. Rb30 waterpump
*10. T78-33 T4 turbo
Rb26 head is still available, i accidentally wrote last time that it is sold. Ahh if i could just edit my own posts like it always used to be possible that'd be great.
  • 1 month later...
 Share
    • well, to check fuel pressure all you need is a gauge and a 8mm joiner with a gauge port in the inlet fuel line; if it stalls at idle when hot you can open the bonnet and check pressure at that time; the fuel pump is a potential cause for what you are describing but it could also be wiring to the pump getting hot. You haven't mentioned that the factory fuel flow control on the fuel pump earth is removed. So either way, it is worth running a suitably sized and fused wire from the battery to pin 30 in a new relay in the boot.  Use the ECU trigger wire into the standard fuel relay to pin 86. Earth relay pin 85 and the Fuel Pump negative (nice big wire for the latter too). Run relay pin 86 pin to Fuel Pump +. That will remove multiple possible fuel pump wiring issues in a 30+ year old car
    • I've been running a 525 for years with the standard hat and FPR in the stagea (mine has a 32 gtr fuel rail and stagea and 32 hat and tank setup are the same) without an issue with base fuel pressure. You said when you disconnected the return it is OK, did you do so at the fuel rail or the fuel hat? Either way I'd be looking for blockages or in the case of the tank kinks in the lines downstream Note I did however have an issue with the current required for the 460 melting the fuel hat.
    • I'm trying to maintain stock appearance . Hicas is still installed (although has lockout kit) did you retain factory fuel pump hat? If so I assume you used a bulkhead fitting or similar ?  I was also trying to avoid a full re design as it was previously dynoed at 426kw atw with same setup but different pump. Changing return line would also mean having to change ethanol sensor and fpr and possibly fuel rail. Not chasing more power in any way just reliability of the setup
    • I do think it's weird I had it for 2 weeks then the issue came up out of nowhere and progressively got worse. I would've imagined changing everything in the ignition system would've resolved any ignition related misfires but still has the high rpm and idle misfires that seem unchanged. I would've thought if it was fuel related it would happen all the time unless it's the pump losing pressure when it gets hot. If it was the ecu I would think it would do it all of the time.  Something I noticed when I had it all apart was a pretty decent coating of oil in the J pipe coming from the throttle body. The weird thing about that is the pcv that goes to the intake is blocked off. So that has me wondering if the oil is coming from the turbo because that's the only thing that could get oil in there. This thing does sound like it spools like a mofo like I'm a former dsm guy and the only stock turbo I've ever heard spool this loud (to only go up to about 5psi) is on a diesel truck. And the recirculated bov is really loud too I had a TurboXS RFL and this thing is just as loud and being so low on psi seems a little weird. I don't know if any of this is or isn't related but just trying to make sure I'm not leaving any potentially helpful information out.
    • So latest update. I replaced the ignitor with a jspec unit from enjuku. It felt a lot better at first although it is a little bit cooler of a day than it has been. Warming up didn't have as much misfire sputtering as before. Went on a 10m test drive. Felt good, a lot stronger though I was taking it easy on the boost. On the return trip started getting the cutting out at higher rpm again and was getting worse the longer I was driving. Took it easy the rest of the way home. Before turning the car off was getting the normal idle sputtering I was getting before.  So where I'm at now, entire ignition system has been replaced with upgraded components. Plugs still gapped at .8mm. Removed the fuel cap in case it was building too much reverse pressure I'm the tank, didn't help at all. Now I'm still on the same tank of gas the fuel treatment was in, I'm thinking if I can run that out and then refill with fresh 93 maybe  the treatment is too concentrated in some areas but doesn't explain that it only does it once the car is warm. I'm leaning towards fuel pump or injectors but if the injector was clogging I don't think it would make it shut off like it has but then fire right back up like nothing happened. So my current guess would be the pump. Without a fuel pressure guage no way to test or check it while it's running.  So that's kind of where I'm at. Need to start testing fuel components and ecu/wiring but I'm at a loss of what's the next logical step and procedure for testing it.
