  • Replies 44
Updated:
R32:
R32 GTS-T/GT-R Rear Windscreen (2 available) - $350
R32 Coupe Door Trims Pair (Suede has been ripped out clean, can use as is or stick on yourself) - $200
R32 GT-R Interior Carpet, Good condition - $250
R32 GTS-T Interior Carpet, Good Condition - $150
R32 GT-R A-Pillar Trims Pair, very good condition - $250
R32 GT-R A-Pillar Trims Pair, 1 side has 3 or 4 broken clips - $150
R33:
R33 Engine Splash Tray (4 available) - $50
R33 GTS-T Full Boot Trim (2 available) - $200
R33 GTS-T/GT-R Boot Slam/Scuff Panel (2 available) - $40
R33 GTS-T M Spec Side Skirts in QM1 Polar White, good condition - $200
R33 GTS/T Midnight Purple Driver Side Guard - $100
R33 GTS-T S2 Grille M spec - needs mesh (Supercheap Auto has meshes, cut to fit) - $80
R33 GTS/T Series 1 Passenger Side Headlight, good condition - $150
R33 GTS/T Series 2 Front Fog Lights/Indicators - $300
R34:
R34 Cabin Filters - To suit all R34 Models, BRAND NEW aftermarket - $35
R34 NISMO GT-T Automatic Cluster - $450 (GT-T Models only, may work with HICAS NA's but can't guarantee)
R34 Under engine splash Tray (3 available) - $50
R34 Sedan Side Skirt (LEFT ONLY) - $120
R34 OEM Fog Lights Pair - $200
R34 GT-R V-Spec Differential - $900
C34 Stagea Bonnet, Series 2 in black - $250
One Size Fits Most:
New Gates Racing Timing Kit to suit all RB - 4 available - $200 ea.
RB26 Rocker Covers (no coilpack cover or timing cover, powedercoated wrinkle red) - $450 pair
RB25 Raceworks Fuel Rail, new, fitted and removed, never used - $120
RB25 ARP Head Studs 202-4301, NEW SEALED - $250
RB26 ARP Head Studs 202-4207, NEW UNSEALED BOX - $400
Mongoose M20S Alarm System (8 available) - $120
Genuine Nissan PCV Valve Grommet, suits all RB, VQ, SR, CA, VR etc. - $10
Genuine Nissan RB25DET M/T Speedo Gear Cog 32743-30P20 - $20
Genuine Nissan RB25DET M/T Gearbox Yoke Seat 32870-V5003 - $40
Genuine Nissan RB25DET R33 M/T Gearbox Yoke Bush (big type) 32861-01G00 - $20
Genuine Nissan RB25 R33 R34 Gearbox Yoke Bush (small type) 32861-H7301 -  $10
Genuine Nissan R33 R34 M/T Speedo Sensor 25010-21U00 - $200
Genuine Nissan Oil Pump Gasket RB Engines 15066-71L00 - $20
Pro-Torque Rear Main Seal, suits all RB - $35
Permaseal MLSR RB25 Head Gasket    S4413MLSR, new sealed - $250
On 27/04/2017 at 1:43 PM, frostyboy said:
Could you please post a picture of the splash tray to suite r33 gtr
And also looking for under gtr wing plastic trim
sorry dont have to suit GTR
On 28/04/2017 at 3:59 PM, Bobtek said:
Do you have the R32 GTR rear parcel shelf? And if possible to post up some pics of the R32 GTR door card trims? Thanks
parcel shelf sold. PM me for door card and trims
    • Nice work on the shroud/ducting.
    • Hi and best of luck with your car. Its a bit hard to tell how low the car is all round from that pic or if its been lowered or not. 90mm is a bit low on the front apron but it depends on the shocks & springs condition & whether or not its been lowered. Going to 19” wheels will give you 15-20mm depending on rubber but you might need new shocks. Mine -2005 are weeping fluid slightly but have lasted 19years!!. So if yours are original they need replacing anyway if they havent been touched before.
    • Hi everyone, Recently got handed down a 2004 Skyline 350GT Coupe. I would like to change the wheels as the previous owner installed some weird ones. The current ones are 215/45ZR18, unsure of the offset, and sit pretty deep in. Would like to increase the ground clearance slightly as well as I need to get it roadworthy standard, currently sitting at 90mm. Was thinking that maybe I could kill 2 birds with 1 stone by getting new wheels.  Pictures of current wheels: https://imgur.com/bg1QMIu Any recommendations for the types of wheels I should be on the lookout for? Like the maximum and minimum offset, sidewall height, width, etc.  Sorry in advance if I'm noob, I do not know much about cars other than how to change the oil, a blown tyre and brakepads....
    • Hey MinKer, Where abouts did you get that table from ?
    • Most likely your engine is toast, but also the R32 GTR has different ratios than the GTS4. In 5th it's basically the same, it's mostly 1st through 3rd that change. Stop trying to do WOT pulls before you make the engine entirely unsalvageable. Do a leakdown test and/or borescope the cylinders first. And a boost leak can overspeed a turbo. Make sure the turbo actually functions as intended.
