S13 Sprint/Time Attack Style Build
No Crust Racing
Half the kit is here so got a start. Just jap rears from eBay here in a few days, sleeka spares front kit direct from them, still stuck in Melbourne (rom SA) since the 22nd =\
Realised I do not have a 36mm socket so couldn't remove the rear hub, which is the half of the kit I have. Plan was to disconnect the arms to swivel the knuckle down to remove drive shaft and get access to the bolts at the back, after disconnecting them all the thought occurred to me that I can probably just disconnect the shalf at the diff and push it out of the hub instead and leave the arms, oh well.
Do have a 30mm so prep'd the front. In love with new impact gun, in love with hoist, in love with small 12v power ratchet, Wish I had bought some of this years ago, makes life and working on the car so much nicer.
Car looking even sadder now.
248385489_1033661840761148_1338788465968330988_n.thumb.jpg.154e6f0e6048d3899449ea79ed396966.jpg248452183_257857066286582_7960311502763010934_n.thumb.jpg.0402e735493028d893f5584227405f14.jpg248385489_583160659561359_8741872032550300866_n.thumb.jpg.436d28103ae5e5019d5486d635e254a0.jpg248810378_929941344541159_7877867322769138933_n.thumb.jpg.f6de94db281a8ad6379b24683f4b31e7.jpg249680718_565184201214193_7631578163723178561_n.thumb.jpg.76625126d263c8878113e0fd31f61a5c.jpg248758982_661158768200324_2422228093728264308_n.thumb.jpg.0a191fccda9595bcf141698fcbb9fc58.jpg248896609_253082013437850_518977303396754252_n.thumb.jpg.10ea7d183972ba80e1b87d78a2c54bb3.jpg248783761_245172437631161_1948213710590856319_n.thumb.jpg.0b862dcfdc22342cc5b6f9743aa3aa68.jpg
  • Like 1
Front hubs on, bearings feel quite tight which I read is normal for new assemblies, aimed for the middle of the 150-220 odd Nm of torque on those.
Rear hub and knuckle removed, awaiting some parts. The bushes in the knuckle look good but part of me is thinking do I replace them while it's out? I don't have a bearing press but wondered if they are small enough to be doable in the vice.
I might just price up the bushes and make a call after that.
  • Like 1
Hmm ok, they look/feel fine
GKtech make a poly bush version but it seems the factory one is more like these hard race style, so I assume that would be the way to go.
Polyurethane S/R/Z Chassis Rear Knuckle Bushes (pair) (gktech.com)
REAR KNUCKLE/HUB BUSHING - 6738 | HARDRACE GLOBAL
  • Like 1
well my thinking is they make a big difference to feel and predictability when they are right, and it is hard to impossible to change on the car. Given it's for track use I'd take the time and money to do them while it's apart to save having to chase some weird handling issue in the future
On 01/11/2021 at 10:46 AM, ActionDan said:
Costs the same as a 20t press when both bought from total tools.
I have access to a bearing press through a mate, might be one time I don't buy the tool for myself.
Maybe I'll ask Satan for one ;)
He is always willing to help out, comes at a price though
Definitely do the bushes while you are there but go the whiteline rubber bush as I have found them better than poly bushes or just go to rose joint inserts.
Hoists just make it so much easier to work on cars, smashed out a full service and tyre rotation in 40mins last week.
  • Like 1
Yep I spoke with one and he said that.
The front isn't too bad, you can still get them, but if they break the rear quarter glass I would likely go Perspex as they are no longer made.
I'm thinking I just get them to do it at the fabricators?
Rather than do it here then transport it.
Some spares arrived yesterday, to my untrained eye they look decent.
The block is a legit virgin bore at 86mm.
Crank shows no signs of spun bearings or scoring but will need to be "UV magna flux crack tested" (copy paste from my builder I am not that smart). If it checks out then that's the real gem of this lot as they are getting harder to find.
Not sure if I'll build a little DIY forgie on the side or just tuck it all away "just in case".
252605364_866084057434050_4845325938550573428_n.thumb.jpg.96d10436a22594de1b006df2ec83b2bc.jpg251999050_1032549754250443_2693860023695406787_n.thumb.jpg.3364735d0970ab51e336b4c39676807a.jpg252755723_1497481603963735_3706385462138089936_n.thumb.jpg.3f7a4c9e029db71598243302578eec0f.jpg251979085_2095094200645323_5045372553535212980_n.thumb.jpg.ec4cab736f5c5e6c8d8692f2b67b9c1b.jpg251624828_854906425124296_3175593458913607591_n.thumb.jpg.5f5d245b9df992c82d432de74ef37823.jpg251873639_1492993171177814_4443453459544334082_n.thumb.jpg.2f104e443d51d491ae530dc20c42d922.jpg
251328154_1124253884995471_4709692196272285056_n.thumb.jpg.3bfe4a8533399852e9d65a5607a55a4d.jpg251336815_426708825720119_1186034710132166824_n.thumb.jpg.fd2c0a4aa0ddbfe561acaa16cb0f87ae.jpg252305025_436900421494693_7581199866573982917_n.thumb.jpg.82102ba2d7a71bda8ef49f2e2c3163fe.jpg251475802_1301367260316988_3713400045496219027_n.thumb.jpg.2be26c463f11f8960bf012d4b39b9822.jpg
251999223_2103094829853680_1955990981354034077_n.thumb.jpg.038520f5fad1b8a02efe07abbed6fc7b.jpg251672043_229259902478272_8676108116236144017_n.thumb.jpg.94a2f147ec7d47a1f43a0d37d2525e72.jpg251868592_934344060796259_1440948774982336564_n.thumb.jpg.e084de1559b82a722614a58bc1adb23d.jpg252022895_2276807919125045_3831922053733715264_n.thumb.jpg.4003168ce395945a688e77ef519b3e04.jpg252319573_308840547749412_2233129636928334847_n.thumb.jpg.5b4c5d0b0163e13c21f419b56bf81571.jpg
No Crust Fabrication hard at it last night getting to work on the rear caliper adaptors, feels weird to cut shit up.
Seems to look like the install photos on the GKtech website?
I will have a little test with the cut tabs to dial the welder in. I was going to get a mate to do it, but if I shy away from every welding project I will never learn and big thick steel is more forgiving. Maybe I will just take it around to his place and have a go with his guidance...
There's always just that thought in the back of your mind that if you don't do a good job your calipers might fly off 0_0
Unpacked all the calipers and one of the front calipers has a shit coating so that will likely go back for swap as I wasn't planning on painting them.
256071142_188865356752268_5729289592381033407_n.thumb.jpg.fa3b80ee9aeb1366767e35fcab2c0bd9.jpg254553066_605222500822762_7876207292467822048_n.thumb.jpg.b41b1bb51ec9bfbe1443b0508813586c.jpg254662804_293936672622753_2824228552162613567_n.thumb.jpg.3c032e7a72ef982dcceaf32801d2d74c.jpg
  • Like 1
