Hypergear 21U highflow
Hypergear 21U highflow turbo, made 269rwkw on 98RON on the last owners car. I never ran over 10-11psi due to factory MAF and injectors. Has done around 3500km since being put on my car. Turbo is still on the car and will be removed next weekend. This turbo will make 300rwkw on E85.
$750 ONO, located western sydney.
Nem - 0405691220
  • 4 weeks later...
 Share
    • Because it's rubbish, it got progressively better with each generation but still rubbish when you're pushing the car on the track. Some like it, most hate it.
    • Yeah, I presumed that the pic was of some other car, because of the F. Ikeya arms.
    • Did a little bit this afternoon and pulled the dump and turbo off so I could take the mani off to clean it up and give it a few coats of paint. Wire wheeled what I could get to and then got the sand paper out to get the tight spots. Gave it one coat so far, will do another two tomorrow and see if I can fit it in the oven to bake it for an hour along with the adapter and dbw.  Hoping the exhaust wrap I ordered turns up soon so I can wrap the dump and screamer. Ordered 30M so I'll wrap back as far as I can to help a little with temp next to the box and also the floorpan.
    • Yeah I think overall I’m running the expected power I should be running for now and I’ll just enjoy it for the time being until I get some other parts. Thanks for the advice mate I appreciate it!
    • That's fair enough.  Might be time to just enjoy what you have until you sort the ecu/flex sensor situation. You can pretty much guarantee that you are knock limited and e85 is going to be the solution to more power.
