2002 NM35 Nissan Stage RS Four
Hi all,
The following vehicle is for sale
Year: 2002
Make: Nissan
Model: NM35 Stagea RS Four
Colour: White
Kms: 154,094
Registration Expiry: May 2018
State of Registration: Victoria
Ownership Period: approximately 3.5 years
Reason for sale: want a new car albeit the Stagea has been a great car for my family's needs
Vehicle history:
* oil and filter changes every 7,500 - 10,000kms, with any issues replaced (eg. cam sensor, coil pack, spark plugs, battery connector, wheel hub bearing, CV boots)
* no accidents in my ownership
* car owned outright, no financing/encumbrance
* sold with 2 keys
Additions to vehicle:
* Trust Panel Filter
* Turbosmart Kompact BoV
* Full exhaust system consisting of Scott Customs dump and front pipe, high flow cat, BlitZ NUR Touring system
* Scott Customs Brake Switch Mod
* RDA dimpled and slotted front and rear rotors, EBC Red Stuff brake pads front and rear
* Alarm
* Alpine head unit
* 18x9.5 DTM wheels, with 225/45/18 tyres
* Tanabe Sustec coilovers
* Axis body kit
* Prorack Roof racks
* Nismo floor mats
The bad:
* the car vibrates when braking, I suspect the brakes need to be machined as they be warped or were not bedded in properly
* the turbo is whiney and noticeably loud, I do not know how much life there is left on the turbo
* the front driver's side fender flare is not there
* the rear boot struts need to be re-gassed
* the front windscreen washer jets not pushing out water
* the door key lock needs to be replaced, failed robbery attempt
Conditions of sale:
* no part out, selling the car as a whole
* No RWC provided
Asking price:
* No price has been set.  I welcome your offers.  Best to call or SMS.  Number is 0418 380 366
 Share
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
    • It looks like you've got Ikeya control arms and an aftermarket sway bar, maybe whiteline?  Or am I just going crazy? lol Unfortunately it won't, but what it will do is look really pretty. That's about all unfortunately.  How much neg camber do you currently have? Generally lowing the car dials in quite a bit of neg camber as it is. If you do go down this path, your best bet is get adjustable arms, toe arms (or preferably a good HICAS elimination kit) and traction rods. With all 3 being adjustable, you'll be able to dial out any bump steer that is introduced by playing with the camber settings.
