My E90 BMW 330i
PranK
 Share
Oh I'm happy that you're hating then too (well not happy but relieved) because I was starting to worry about suspension components.
Are you loving the E90?
Yeah I love it!
Most comfortable car I’ve ever owned, ac is great, cruise control, leather.....I could go on!
I’m not a fan of the automatic hi beam/low beam headlights tho. I live in a country town and at night the reflections from all the street signs make the high beam switch off and on a lot which is quite annoying
Also mine has the M-sport package which has the lowers suspension and the car sits lower than my GTR believe it or not which can be a bit of a pain haha
On 1/18/2018 at 5:17 PM, PranK said:
The handling is odd
My E92 was pretty bad on poor roads, have now replaced all shocks with Bilstein B4's and it has improved a lot. I'm still debating replacing the 19" wheels with 18's to further improve ride. I'll need new rear tyres soon, so will decide before I buy them.
Auto hi beam dips the lights automatically when a car comes towards you - your car may not have it. There is a sensor behind the internal rear-view mirror. Have you run your VIN through a checker to see what options are installed? There are a number of free sites - google is your friend.
My latest job was to pull the hard disk out of the CIC, and image it to a new disk. I've had a couple of issues of the CIC getting into a reboot cycle, and I'm pretty sure it's the disk failing. I've got an SSD on order - interface is IDE so not common. At the same time I've also managed to update my maps to 2018.
I have a sensor on the back of the mirror so I'll definitely test the auto high beams.
I wish I knew somebody with non run flats so I could try the car on them. I don't want to follow that route until I'm sure that's the problem. I have B8s on the Bora, definitely the best shocks I've ever had.
I'd love to read about what you do with the CIC. Mine is the CCC but there are upgrade guides for the CIC which have piqued my interest.
So I read the manual and saw nothing about the high beams other than how to turn them on. There was a heap of info about the adaptive xenons, is that what you mean? They change where they point based on steering and speed, they are also auto anti dazzle. I have these and totally love them. I've only driven at night a handful of times (went on holidays not long after getting it and daylight saving hasn't helped) but I love seeing the lights moving around.
Auto headlight is different to adaptive headlights. High beam assistant is described on page 101 of my user manual. The option code on my car is "S5AC High Beam Assistant", and this is what it does (c&p from a google search):
What is high beam assistant?
High-beam assist recognises oncoming vehicles at night, switching headlights between main and dipped beam automatically. It's a very clever bit of kit and is claimed to make nocturnal driving less stressful
Yesterday I received my new OBD port to RJ45 adaptor, which allows a network connection into the CIC via the OBD port. This makes it simple to get the file needed to allow the generation of an FSC code, which in turn is needed to install new maps. I'd already got the file I needed for my car by plugging the hard disk into a Neutrino VM, but had ordered the adaptor from China a few weeks ago and wanted to see if it worked. Now that I have the OBD-RJ45 adaptor and an IDE disk - USB adaptor, I can backup & restore CIC & NBT hard disks, and generate FSC codes for map updates
What is high beam assistant? High-beam assist recognises oncoming vehicles at night, switching headlights between main and dipped beam automatically. It's a very clever bit of kit and is claimed to make nocturnal driving less stressful   Yesterday I received my new OBD port to RJ45 adaptor, which allows a network connection into the CIC via the OBD port. This makes it simple to get the file needed to allow the generation of an FSC code, which in turn is needed to install new maps. I'd already got the file I needed for my car by plugging the hard disk into a Neutrino VM, but had ordered the adaptor from China a few weeks ago and wanted to see if it worked. Now that I have the OBD-RJ45 adaptor and an IDE disk - USB adaptor, I can backup & restore CIC & NBT hard disks, and generate FSC codes for map updates.
Yeah that’s what I mean, the high beam assist haha!
1
Page 101 for me is Keyfob battery changing. :( Maybe you have LCI E90?
Nice! This sounds awesome! Maybe you could do a write up about it?
One super irritating issue I was dealing with was the absolutely useless passenger side mirror.
You can see how bad it was. It was so hard trying to change lanes in crazy Sydney traffic when commuting when I really had no trustworthy mirror.
So, I bought a cheap convex mirror on eBay which has made a big difference though the mirror itself is a bit warped. Its still a million times better.
So much better.
  • 4 weeks later...
Ok, bit of an update.
One thing that gets under my skin with any car is something that doesnt work. Even if I never plan to use it, I just hate that it doesnt work.
Case in point; my electric rear sun shade. One side is broken and it opens kinda strangely...
Add to that the terrible faded parcel shelf and awful condition of the C-Pillar trim, I thought it could all get a clean up.
Hard to see the fade until the tray was out of the car.
Heres the little clip/slider that is broken.
I used JB Weld on it and left it overnight.
But, it just disintegrated again when I touched it, and so did the other side. The plastic was just far too brittle to fix. Another victim of Australian UV I think.
I found a guy in the UK that sells just the runner and clips and so I bought a bunch to replace them all.
This is the state of one of the C-Pillar trims.
The parcel tray looked so much better after a spray, but I totally killed the fabric. Its very hard and brittle now. I don't think anybody will notice though.
When I was playing at the back of the car I looked under at the exhaust and noticed a flap.
With a vacuum activated actuator.
So, after reading online about 330i exhaust flaps and how the second pipe closes to stay quiet at commutting and freeway type speeds (ie, less drone) I decided to block it.
The car sounds great. The noise sticks around when it used to fade away. I wish there was another flap to open some kind of race system... :)
So, the other thing is while I was in the back of the car and rubbed my head on the roof, all the liner started to sag. Thankfully there is a trim piece at the 3rd brake light I can use to get in and spray some adhesive. Because I am far too particular to have a car with a saggy headliner. Its not a Kingswood ffs. 20180218_152911.jpg
Oh, and lastly ...
Over the past month I've needed to top up the coolant twice. With only a small amount, but still. Added to that was an error code (check engine light on intermittently) which related to the VANOS system (variable valve timing). There was zero change in driving or anything. I dropped it into the warranty-approved mechanic today to investigate and he flushed the engine and gave it a solid service. He said that because of the k's (50k) the k's since last service wasn't a lot, but the months since last service was - it was serviced last in 2015. I knew this, I just hadn't done it yet. He was going to clean the VANOS solenoids rather than replace them straight away.
He also said that the seal on the radiator drain plug was leaking. Beauty, easy fix.
So, he called just now and said everything went to plan. Car is running well and no codes. Fingers crossed he's sorted it.
He did tell me that rear tyres need replacing. This has caused a fair bit of thinking because I am considering ditching the run flats and making a spare tyre kit in the boot. The RFT's grab on everything and make rough roads horrible to drive on.
Lots of yanks buy a space saver and kit, or just a foam filler.
I absolutely love this car and have missed it today. Its been a long time since I've been as taken by a car as I am by this.
OK, it happened with the Bora and the GTR's and the Stagea, but whatever. Shut up.
Some nice TLC stuff going on here... But you'd have to be pretty shitty if you bought this car new and all these "old car" issues were happening to it...
I get the feeling a fastidious owner taking care of the car wouldn't have prevented these issues.
I think with all the commodore drivers stealing the X5 rims to put on theirs...
then it only fair that you put gold 21 inch Simmons on this...
or at least on the front and put some steelies on the back..
  • Like 1
Totally agree. But I'm a fastidious owner and it has few enough kay's to undo the wrongdoings (imo).
3
Ordered some 21" Vault chromies.
In seriousness, I happened to find a guy selling a set of 17" MSport wheels with tonnes of rubber (and RFT) on them. Better offset and staggered. Picked them up today.
The wheels have some of the worst gutter rash I've seen, but can't complain for $400 and gives me another project considering upgrades and changes to this car will be minimal for a while.
  • PranK changed the title to My E90 BMW 330i
 Share
    • Nah. Any decent third party diagnostics unit should be able to talk Consult and all the other non-OBD protocols from back in the day. It's only 25 years since OBD started taking over. There's many cars from that ear still on the road. My mechanic's diag terminal is plenty able to talk to the other CUs in my car. Well, those that are still present, anyway. That's probably only the HICAS CU, as there never was an ABS or TCS or SRS CU, and the TCU went in the bin 25 years ago.
    • You'd be better off putting the ATTESA stuff into the boot. Same same but different, and not as bulky as a fuel cell. The space under the parcel shelf is not what I'd call "useful" boot space most of the time, even if I seem to have a guitar (not mine - child's) sitting there most days lately.
    • The main argument for lighter ARBs is that ARBs reduce the independence of the suspension. They link the left wheel to the right wheel. The lighter the ARB is, the less this linkage. When you hit a significant one wheel bump on a car with lighter springs and heavier ARBs, more of that disturbance gets transferred across to the other wheel. Whereas, with a heavier spring and lighter ARB, the impacted wheel is the only one that reacts to the hit. If you hit a significant two wheel bump, then lighter springs are the only things taking the bump as the ARB is not involved (both ends move up/down together). Then the spring rates alone determine how the car takes the hit. Softer springs (to a degree) will be more comfortable. Harder springs will accept the energy input better with less total compression (but obviously possibly more undesirable and probably uncomfortable body movement). The other significant thing to remember is that spring rate is really about coping with the rate at which loads are input to the suspension. Driving around slowly? Then any bump you hit is going to feed load into the suspension at a low rate, and you can use a low rate spring and with a low rate spring the damper has to less work to control the spring's motion. This describes street usage because it is mostly illegal to go fast or drive aggressively enough to require handling fast load inputs. But if you're going at racetrack speeds (or rally, or anything where going fast over whatever the surface is) then the loads get applied faster and you need to control that input with more spring rate, and then the dampers have to do more and that's why it all starts getting expensive. Anyway, the point of all that is, it's complicated, depends on usage and surface quality, and it's why proper race cars have a lot of adjustment and will even completely swap out springs and dampers when going from one track to another. One track might be smooth, and so even if it is a fast track there won't be rapid load input. Another track might be as rough as guts, or it might have a couple of sets of tight esses on it that require the car to heave from side to side. The rates at which loads get fed in will be different on those two tracks and probably require completely different setup. Three paragraphs and 400 words are nowhere near enough to convey how complicated this subject is and also I am nowhere near the right person to write a treatise on it, as it it not my field of expertise, or even keen interest. There are many books written on the topic, and as alluded to previously, they take differing approaches to accepting the compromises involved. So you can't read just one and think you understand.
    • Personally, i'd be dropping the extra $400 for the Pro series. I believe (at least during their original conception) they were based off the Blue series but have evolved with apparent new valving tech etc etc.  The BC's were super harsh ride wise, felt like the road was covered in potholes almost (this with damping at softest), but they did feel a bit more pointy initially through corners, i felt like there was considerably more understeer at turn in on tighter radius corners (but this is not really a like or like, considering the difference in wheel size, tyre choice, track temp etc etc)
    • Facts but it's okay I've ordered a new ignitor based on GTSBoy's confidence. In the meantime I did the ole jiggle tap on the maf connector with no change. Seems like the warmer it gets outside the worse the issues get. Hoping it's the ignitor. Also going to pick up some carb cleaner and try to get that iacv cleaned out real good. I'll report back once I've gathered more data. I really appreciate the feedback though guys keep it coming. Trying to learn everything I can about this car want to keep this thing for a long time.
