Hi guys,
Apologies, I know this might seem like a stupid question to some of you.
I've just bought an R32 GTR. Link ecu, single turbo etc.
The crankcase breather setup is- all stock except breathing into a vented catch can instead of feeding back in before the turbo. Now based on previous experience this makes for a huge vacuum leak!
Tonight I tried blocking off the pcv and simply breathing both valve covers into the catch can. The car idled at 900rpm (usually 1100rpm)  and sounded slightly less 'lumpy'. The car is currently on stands so can't drive it unfortunetly.
My question is...is it possible the car was set up and tuned with the stock but vented set up (vac leak). Or is that likely an uneducated modification by a previous owner. Obviously no mafs with the link ecu. But I cant see how the ecu can measure the air coming in through the pcv valve when off boost.
Thanks heaps, Luke
 Share
    • Yes indeed ; They offered it to me, I'm waiting for their quote 😉
    • Hey, thanks dude. Freedom to do whatever one wants to with their own car and build, but personally I don't want anything that's too precious. If I can't beat on it when I feel inspired, what's the point of having a car like this? And if I break something, it's me who's going to be fixing it myself...
    • https://files.fm/u/nrm9zrpkjj
    • Admin delete if not allowed please, I just purchased an r32 GTST with a Gtr front bar , grill I assume bonnet? (maybe) I have 2 questions he told me it had an RB25det I’m new to the RB world, and this is the photo I have taken and also I noticed a piece near my suspension broken is this fixable , will update new photos tomorrow once I have lifted her up and removed the LHS wheel I want to know if there is ways around this , I didn’t notice anything as it drove with no knocks on the suspension or weird feeling    the car feels sluggish, and the rpm cluster literally goes to 3.5-4k rpm and when you put your foot down it dances around like the local girl on Canterbury road or Sefton playhouse the car sat for 8 years he said the oil was dropped and re done , I noticed the oil was very clean car starts no problems by all means it’s not a clean car it is a project but doesn’t need much, knowing me I will go overboard the colour is horrible car has 88k kms hardly driven needs a few things but it’ll be fun to build properly    so guys is this an rb20 or rb25 and what is this bracket called? Can it be fixed thanks
    • found this on the forum , suggests I am in the range  ----------------------------- From the segmented (potentially incorrect) information I've found that;  Early R32: RB26000XXXX to RB26002XXXX  Mid R32: RB26003XXXX (V-Spec I RB26-03XXXXX - Reference Classic Register) Late R32: RB26004XXXX (V-Spec II RB26-042XXXX - RB26-045XXXX - Reference Classic Register) Early R33: RB26005XXXX Mid R33: RB26006XXXX (as per the engine in this R32 V-Spec II, which is what I'm concerned about from legitimacy perspective) Late R33:  RB26007XXXX Early R34 (2000+):  RB26008XXXX ----------------------
