Hi there. Having some issues with axel tramp in my a31 cefiro (Same as r32)
Only occurs when I first drop the clutch in first for about half a second then it will light up normally
Also happens if I change gears hard during loss of traction. Ie 1st to second and dump the clutch
Have bc gold suspension and have fitted locking collars (pineapples) however they were no help.
Any ideas what's up?
Well, after my previous suggestion, the list of things that can cause axle tramp includes,
  • Tyre compound,
  • Tyre pressure,
  • Control arm bush compliance, (specifically worn, damaged, or simply mismatched between upper and lower arms, etc),
  • Driveshaft twist,
  • Hub spline wear,
  • CV joint wear,
  • Diff bushes,
  • Subframe bushes,
  • Damper settings (should have put this one closer to the top, but I don't believe that adjusting dampers to fix axle tramp as the first priority is the way to set a car up - you should set the dampers to control the springs in normal usage, which is cornering),
  • And, probably, even anti-roll bar stiffness and/or the bushes in the links on the ARB.
Does that help?
You can't check for twist.  All such shafts twist when loaded.  An example, the tailshaft in a 928 racecar I knew of (actually, it's a torquetube, but that's not a problem) twisted up to 8 full turns on launch!  Short axles like on your car won't twist that much, but they still twist.  The problem with that twist with regard to axle tramp is simply harmonic motion.  You load it up, it twists until it is transmitting the torque to the tyre, then the tyre breaks traction and the shaft rapidly unloads and untwists the shaft which will "untwist" past the neutral point and recoil, oscillating around the neutral point.  This happens in all such shafts, but sometimes it just reaches a condition where it drives the oscillations instead of allowing them to dampen out.  The same is true for all the other causes of axle tramp.  It's something that's moving or soaking up the torque, then releasing it and allowing it to swing back and forth without damping away.
  • Like 1
I took my mechanic for a drive today just to show him whats up. He got out and I dumped it and he said the wheels werent hopping at all. We put it in the air and he wasnt black and white sure but he things it might be my hanger bearing. I'm hoping this is the case. However I've recently installed an rb25 big box and hence had a custom driveshaft made up..
 Share
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
    • It looks like you've got Ikeya control arms and an aftermarket sway bar, maybe whiteline?  Or am I just going crazy? lol Unfortunately it won't, but what it will do is look really pretty. That's about all unfortunately.  How much neg camber do you currently have? Generally lowing the car dials in quite a bit of neg camber as it is. If you do go down this path, your best bet is get adjustable arms, toe arms (or preferably a good HICAS elimination kit) and traction rods. With all 3 being adjustable, you'll be able to dial out any bump steer that is introduced by playing with the camber settings.
