OK so need some help please people just turbod my na r34 and am checking if what it's doing is OK before my tune on Thursday OK so I'll start with parts I'm running... And post problem last
Rb25de neo
R33 5speed gearbox conversion
Was using rb25 one but think was near dead New rb25turbo hasn't arrived yet
R33 turbo manifold
Gtt injectors
R32gtst4det fuel pump
Power FC ecu stock gtt base tune atm
Big front mount cooler
Turbo smart bleed valve
New 3"pipe decat and r32 custom dump
R34na 02sensor
R32gtst4det afm I wired in also tried 34 na one OK so my problem is it misses bad under boost only.. disconnect turbo runs sweet can this be my ign timing when boosting?  Just want it all good and ready for my first tune as never had one what should I get done in the tune and what boost 5? And just get fuel/air and some timing pulled/retard etc...also haven't tried yet as my new turbo is on its way but the one I was using was blowing smoke and whining and no matter what it was stuck on 7-8 psi my hand controller wouldn't turn it down so waste gate? Over boost could've been the problem?
Edited by R34 rocket bunny sedan
 Share
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
    • It looks like you've got Ikeya control arms and an aftermarket sway bar, maybe whiteline?  Or am I just going crazy? lol Unfortunately it won't, but what it will do is look really pretty. That's about all unfortunately.  How much neg camber do you currently have? Generally lowing the car dials in quite a bit of neg camber as it is. If you do go down this path, your best bet is get adjustable arms, toe arms (or preferably a good HICAS elimination kit) and traction rods. With all 3 being adjustable, you'll be able to dial out any bump steer that is introduced by playing with the camber settings.
