Besides the exhaust, here are all the parts I intend to buy to complete my stage 1 r33 build. The car is currently stock. Is there anything else I should buy or replace for something else on this list? This is a budget build but I also don’t want to cut any corners so any tips would help. I am sure I am missing some parts, especially with the bigger fuel pump. Thank you
A lot of what you posted is junk.
If you want to keep it affordable look at; Second hand power fc, new walbro pump with rewire, boost tee, any off the shelf exhaust used/second hand same thing, new z32 afm. Should be able to do that under 2k tuned.
Thanks for the advice but a second hand power fc will still be too much for the benefits and I hear of problems with boost tees, i won’t deny they give great power for the money tho. I will definitely look at Walbro pumps and a z32 afm. With a new fuel pump is there anything else I should get to support the extra fuel flow?
I’d have to spend more money to not be that retard haha. I could just get a new waste gate actuator and super afc and make as much power as a power fc with a boost tee but for less $. I debated this same thing for awhile with myself, but after all I’ve read and heard I’ve made up my mind
If you have made up your mind what exactly are you looking for?
You should take advantage of people selling power fcs. These days people are going haltech or emtron or something newer. Second hand power fcs can be had for under $500. Most importantly it plugs in. No cutting of wires like your safc. Thats cheap af for a full ecu. If you are budget conscious get a jaycar digital fuel adjuster lol seriously, there is no good excuse for getting a fuel controller with so many other affordable options these days.
Z32. Piss off stock afm.
Boost tap is cheapest option and it works. If you want incar adjustment look at an ebc. Makes no difference. Set the boost 14psi and leave it.
Entry level and good hp/$.
After that injectors turbo and front mount.
Can i ask where you are located? If you're in Australia, then nistune is going to be a better solution than an safc and won't cost much either. You just need a factory nissan r32/z32 ecu, probably $100 2nd hand and a new nistune board installed is probably around 4-500 aud. It will plug straight in, no messy wiring and will work well, have modern features and be fully tuneable. Sounds like you've made your mind up but that's my 2c worth. Good luck.
  • Like 1
Okay okay. You and others seem pretty adamant about me getting a power fc second hand so I’ll start looking and I guess grab a boost tee. I am only looking to push my boost to about 10 psi, maybe 12 max. I don’t need my car to be insane and want to not push the stock turbo. With that amount of boost is a z32 necessary or can I run stock afm at 10 psi? My goal is r33 gtr power in a gtst so like ~280whp
You wont need the z32 afm for that power. Power fc, boost t, 3 inch exhaust and 11-12 psi will get you around 250-260rwhp. An r34 gtt turbo will get you closer to 280. You'll probably need a proper intercooler too. You're in Japan, so parts shouldn't be hard to come by.
For stage 1, why dont you just go:
• full 3 inch exhaust
• R34 GTT intercooler
• Boost T set to safe 10psi
• Apexi pod filter (don't think this is necessary)
I had my r33 dynoed at 180rwkw (245hp) with these mods.
I was under the impression the stock ECU was kept in stage 1 mods.
Keep in mind that your rwhp and his rwhp are no necessarily the same thing.
Let me put it to you another way.  I have an RR25 Neo.  12 psi boost, big exhaust, FMIC, big cold air induction.  It makes 191rwkW.  Without the tune that is in the Nistuned ECU it would not go anywhere near that much power.  It would be deeply f**ked by R&R.
You need it tuned.  Buy a PowerFC. Don't stuff around.  And don't expect the R33 turbo to hold together at 12 psi either.  it might, or it could shit itself in days.  Spin the wheel, take your chances.
You don’t run an aftermarket ecu with that setup? I’m looking to make about 20 more hp at the wheels than that
Yep stock ecu, at 10 psi boost it ran with no issues and didn't hit R&R.
But my mistake, i had a blitz return flow intercooler not an R34 GTT one.
 Share
    • Y'know what, after reading a topic on a 360kw build using a nistune (who ended up going LINK), im now considering a LINK over a nistune. The engine protection alone would probably be worth it. And id like to learn to tune so would be nice to have that safe guard. Which means i probably wont need a boost controller then, or the R35 MAF.  Becoming a bit of a blog now but oh wells. As mentioned previously, the goal is around 300kw, for a daily driver. Will be looking at fitting a highflow turbo or similar (something that doesnt require downpipes, manifolds etc to be changed out) when the current stock gives out or the money for it is there.
    • Thanks guys. Are you meant to tighten the converter bolts through the starter motor hole? Think my plate between gearbox and engine is one piece. Im heading up there tomorrow.
    • Picked my tailshaft up yesterday arv!! Test fit it and because they've gone to a ford centre bearing and CV I had to modify the mounting bracket a little bit. 5mm of each side and she went up into position and fits well. It has a 1350 uni and flange on the gearbox end so it should be plenty strong!  Got stuck in this morning and started on the wiring mess. Cut out all the wires not required that go to the body connector and cut the engine harness out. Need to go through and work out which ones I need to keep and rewire into the new ecu. Should save a small amount of weight as well. I'd love to get in and rip the dash and everything out to completely remove wiring but cbf.  Next up was the power harness for alternator, starter etc. It has a few connectors from factory that run out of it. Cut it all apart and removed what was no longer required and put some new corro and taped it all back up and bolted it all back into place.  After that I worked out where I can mount the new flex sensor. Found a couple of factory bolt holes and drilled a new hole on the bracket to suit. Need to go get a few fittings and adapters tomorrow so I can keep going.
    • Nah, im after the more newer looking, one with the OLED display
    • We revised the neutral wire instructions. The old way was wrong.  R34 gearbox change.pdf
