Neo 33 turns but won’t fire
Reeky
 Share
Ok here’s a list of exactly what I’ve done for my r33 neo. This is whilst retaining all r33 bolt ons, plenum, oem coilpacks with the loom, injectors & rail with the loom using a s2 R33 rb25 engine loom and starter motor loom.
comtinues to turn really strong, but no firing up. Fuel pump works fine
-changed plug for o2 sensor to suit neo
-changed vct solenoid plug to suit neo
-extended the TPS plugs to reach neo throttle body
-reversed cas
-variable air control intake solenoid valve plug changed to suit neo & canister purge control valve plug to suit neo
That’s about it. IGN relay is there, ecu is in, white thing is plugged in I’m pretty sure it’s in properly.
On 9/16/2018 at 5:27 PM, hey_aleks said:
Send a pic of your engine bay aswell.
All lines are correct, filter is correct feed way so is the reg, all on the correct flow ways
On 9/17/2018 at 12:13 PM, iruvyouskyrine said:
1 and 4 (outer wires) need swapping on plastic CAS
I gave that a go and still no fire up, tried these combinations
4231, 4321, 1324 and still no go
On 9/16/2018 at 10:44 PM, robbo_rb180 said:
Pull out cas and turn it, listen for injectors and also pull off no1 coil pack and see if it creates a spark.
From memory the 2 middle wires on the cas need to be swapped for the plastic covered to be used with normal metal ones.
So 1324?
 Share
