Help with my R33 GTR wheels and spacers
Hi everyone, I need your help on getting spacers for my GTR. I thinking of adding 10mm or 15mm but am finding it hard getting the right spacers as the centre bore is the exact size as my current wheels so how do I get spacers that will fit my wheels on top?
As you can see from the attached photos, I bought a set of 10mm spacers and the centre bore won't fit through my wheels. I've never looked into spacers before so am needing some help.
Specs of 10mm spacers that didn't fit were:
PCD: 5/114.3 with 66.1mm center bore and 73.1 OD
What specs would I need for them to fit? I only need 10mm or 15mm.
Thanks all.
Thanks all.
I think the problem you had was the OD was 73.1mm it needs to also be 66.1mm.
And it looks like those spacer are slip-on ones not hub centric? Also be careful as you may ruin your AWD system with different wheel diameters but I've never fitted spacers to my car before so others can confirm
Why do you need spacers?
  • Like 1
3 minutes ago, djr81 said:
Not 100% sure on this but:
You can get rims in 66.1mm diameter centre bore and you can get them in 73.1 diameter.
You appear to have bought a spacer that allows fitting of one to the other
You are right on this...Rays produce wheels in both specs. I think the OP mentioned that spacers with the OD of 66.1mm was the same as his wheels which didn't allow fitment so not sure either.
  • Like 1
22 minutes ago, UWISSH! said:
Get the correct size rims.
Spacers are a terrible idea and not in the slightest bit legal.
Did u also get extended wheel studs?
I was thinking the same too.
A friend ran into issues as he didn’t have enough stud thread left and his wheels were barely hanging on.
Looks is one thing but safety is paramount.
  • Like 1
Looks like you have 19x10 +22 wheels, they should fit without issue.
If you're after more "stance" I suggest selling the wheels and getting ones with +12 offset.
You can get spacers, but then you need to buy longer wheel studs, and also you car isn't roadworthy.
  • Like 1
Hey mate, although getting wheels with better offset is probably the way to go I can appreciate forking out extra cash isn't always an option for most.
If you must use a spacer (can be safe if only done right) then use a hub-centric one (sits flush onto the wheel's hub). The ones you have although would have been hub-centric are split-on ones with no extended studs you would would have had to get longer studs for them to work with your current wheel.
Alternatively and is the better option, get hub-centric one with their own extended wheel studs so they would sit on your current studs then have their own protruding studs whereby your wheel would sit on. Make sure the PCD and and centre bore diameters are correct for your car and be mindful of some rubbing when turning or cornering. For the rear of a GTR and based on your wheels offset, I reckon 15mm is max do not go any further.
Good luck.
  • Like 1
Thank you for everyone's replies. It is much appreciated.
I got my rear guards flared so it is a little wider than stock which has add about 10mms from memory hence despite the wheels having good offset I don't know if it's sitting out enough yet.
I'm chasing the R33 400R look so as you can see from the photos, it sits just out be still a little tucked under the guards just like how the 400R looked so many people say my wheels look nice and flush as is no need for spacers or do I still nee them?
The problem is I only have around 8-10mm clearance left on the guards so any further spacing and it will probably rub.
Photo03.thumb.jpg.d555effbf32854c2a8802a26cb09802b.jpgPhoto04.thumb.jpg.01ffddd6a6837c0aa664749d552c6eff.jpgPhoto02.thumb.jpg.acceb5fe014fc400d6129e88d1b2bdd7.jpgPhoto01.thumb.jpg.8e86efcca172605dd2ac1b3335fbb2fd.jpg
Nismo02.JPG.73f025e9bb22d570073ceed39e4ce66d.JPGNismo01.JPG.75ce987159f46605772626f1c8690771.JPG
I think your wheels are nice as is no need for spacers which would defect your GTR and cause issues. Your wheels are sticking out a lot already and the rear looks very similar to the 400R’s.
Edited by Robocop2310
  • Like 1
Those 400R wheels are 18x10 +20, with those wheel arch lip things.
You don't need spacers. If you want a more flush look, run 285 wide tyres and wind out the upper arms for less negative camber.
Or, sell your wheels and get 10.5 +12 ones. Messing around with spacers is frowned upon. But hey, you car, your money, you do what you want.
  • Like 1
  • Thanks 1
Well said totally agree. I second you don’t need spacers good as is. ?
  • Like 1
Thanks everyone! I think I'll just leave them as is and run wider tires next time when they need changing.
Many thanks!
 Share
    • I can believe it if you're getting air into the pickup. Cavitation is tremendously destructive for pumps.
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
