Will these specs will fit?
kye32gtst
 Share
So I'm looking at getting some wheels for my R32 GTS-T and I want to know what I can fit under the gaurds without doing any of this stupid stretching of tyres. I'm looking to get 17x8 +32s under all corners. Is it gonna work with 235s or 245s? Gaurds already rolled of course
But the short answer is yes.  This is probably the first of the 14000 such threads on this forum where the OP intends to fit sensibly sized wheels and tyres.
+35 would be better than +32 (which will poke out a tiny bit more than the 35s).  But GTR wheels are +30 and they fit fine.  235s a better choice than 245 (which will bag out a bit more and may just scrape on the guard lip at +32).
Thanks for the info.
The reason I can't just go to WillTheyFit.com is because it currently has steelies on it. Wanted a straight answer from people who have already tried
Why are you buying Subaru wheels? Look at the crapload of posts here.
No one has put 17x8 +32 all round because that's a very rare size these days. As mentioned, GT-R was a popular wheel choice, which is 9" +30. Look on willtheyfit and use your imagination (since you don't want to use a tape measure).
 Share
    • Y'know what, after reading a topic on a 360kw build using a nistune (who ended up going LINK), im now considering a LINK over a nistune. The engine protection alone would probably be worth it. And id like to learn to tune so would be nice to have that safe guard. Which means i probably wont need a boost controller then, or the R35 MAF.  Becoming a bit of a blog now but oh wells. As mentioned previously, the goal is around 300kw, for a daily driver. Will be looking at fitting a highflow turbo or similar (something that doesnt require downpipes, manifolds etc to be changed out) when the current stock gives out or the money for it is there.
    • Thanks guys. Are you meant to tighten the converter bolts through the starter motor hole? Think my plate between gearbox and engine is one piece. Im heading up there tomorrow.
    • Picked my tailshaft up yesterday arv!! Test fit it and because they've gone to a ford centre bearing and CV I had to modify the mounting bracket a little bit. 5mm of each side and she went up into position and fits well. It has a 1350 uni and flange on the gearbox end so it should be plenty strong!  Got stuck in this morning and started on the wiring mess. Cut out all the wires not required that go to the body connector and cut the engine harness out. Need to go through and work out which ones I need to keep and rewire into the new ecu. Should save a small amount of weight as well. I'd love to get in and rip the dash and everything out to completely remove wiring but cbf.  Next up was the power harness for alternator, starter etc. It has a few connectors from factory that run out of it. Cut it all apart and removed what was no longer required and put some new corro and taped it all back up and bolted it all back into place.  After that I worked out where I can mount the new flex sensor. Found a couple of factory bolt holes and drilled a new hole on the bracket to suit. Need to go get a few fittings and adapters tomorrow so I can keep going.
    • Nah, im after the more newer looking, one with the OLED display
    • We revised the neutral wire instructions. The old way was wrong.  R34 gearbox change.pdf
