For sale black 2002 nm35 stagea with vq25det.  Beautiful 2.5 litre v6, turbocharged awd wagon. Twin sunroof model. Nice kenwood headunit with two amps in boot and rockford fosgate splits up front.
Has Queensland rego to May 2019 - bring your own roadworthy or we can negotiate a sale price unregistered. Dont have the passion anymore for it so if you have the time and love to give this could be a very good buy.
$10,000 OR NEAREST OFFER.
NO SWAPS, NO PARTOUTS
Have replaced in my ownership
rear upper control arms (oem),
front castor arms,
rebuilt front cv shafts,
replaced rocker cover gaskets (oem),
coil packs (oem),
ngk iridium plugs,
all timing chain tensioners and guides (oem),
water pump and thermostat (oem),
front right and rear left wheel bearings (oem),
front ball joints,
front swaybar endlinks (oem),
Rear swaybar links (Whiteline heavy duty adjustable),
Replaced BOV hoses with new silicone items,
Replaced rubber suction pipe with custom made alloy pipe (Capalaba Exhaust Innovations),
rebuilt steering rack.
I have fitted:
Scotty dump and front pipe with 100 cell cat
Scotty modified wastegate actuator with approx 13psi spring
Hdi ebc set at 15psi
Turbosmart boost guage
Hdi front mount
PWR transcooler and derale fluid thermostat
Ten inch Davies Craig slimline thermofan
Brembo brake pads front and rear
Z1 motorsport USA rear subframe alloy inserts
It also has hks hypermax ls+ coilovers, 3 inch mandrel exhaust and hks turbo timer which were on the car when i bought it.
Fresh Penrite synthetic fluids throughout. Has Chrysler 300C 18 inch alloys with good condition Michelin pilot sport 4 tyres.
Regularly serviced at 5000km intervals with synthetic engine oil and nismo filter.
Many small things done as well like replacing old vac lines, breather hoses etc.
Have spent thousands maintaining and improving but with a very active work and family life i just dont have the time to give to it anymore. Always garaged, non smoker, cleaned weekly inside and out. Lovingly maintained as can be seen by the maintenance list above. Have a record book full of all the work i and others have performed with part numbers. Runs and drives perfectly. Someone buy it before I fall in love with it again and my wife beats me with a stick. My loss is your gain. Located Brisbane bayside.
  • 3 weeks later...
 Share
