FOR SALE: 1992 Skyline R32 GTS-T
Hi
For Sale: Nissan Skyline R32 GTS-T M Spec
Registration: Unregistered
Kilometres: 170, 848
Colour: Gun metal grey
Details:
  • Genuine R32 GTR front end
  • Rota grids wheels
  • Coilovers
  • Front mount intercooler
  • Boost controller
  • Pod filter
  • Cat back exhaust
  • Blow off valve - Greddy type RS (quite)
  • New Dayco timing belt
  • New front pulley belts
  • New bearings, crankshaft and camshaft seals
  • New rocket cover gasket
  • New water pump
  • New HD excedy clutch, seals and spigot
  • New diff, gearbox and engine oils
  • New inner and outer tie rods
  • New inner and outer tie rods, front and rear boots
  • New rear brakes (Bendix)
  • New spark plugs (copper)
  • Radiator flushed and new fluid
  • Saas boost gauge
  • 6" speakers, amp, new sub
Interior:
  • No bubbles on dash
  • Clean and Original interior
  • Blue dash lights
Body:
  • Paint faded on drivers side rear quarter
  • Few chips and other minor imperfections
Other inclusions:
  • Original 4 x R32 GTS-T wheels and tyres
  • R32 GTR injectors (Not fitted)
  • R32 GTR  centre triple guages (Not fitted)
  • Blast Pipes (Not fitted)
  • Turbo Timer (Not fitted)
  • 6L Penrite fully synthetic HPR10 10W-50 plus oil filter
Other Details:
  • 1 x genuine key plus 2 copies
  • I have owned this vehicle for 5 years
  • Tow away and will require blue slip for registration. Will pass (Passed when I bought it to transfer to NSW rego).
  • Have all receipts from work completed by me including some receipts from previous owners, some dating back 2003.
  • Recent issue while registered - Does occasionally turn off while driving but while start up again and run. I suspect this is due to fuel filter will need replacing.
  • Garaged and unregistered for the past 3 years.
  • Reason for sale is no longer having the time to work on the car and enjoy driving it.
Price: 12,500
Contact: Please inbox me for any questions and further details.
NOT INTERESTED IN SWAPS, STUPID OFFERS OR TIME WASTERS!
Thank you.
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
23 hours ago, highwaycruiser said:
Jerking reaction occurs  randomly while driving.
no doubt! ?
Note - i read this as 'action' not reaction.  No i have read it properly it's less funny
Edited by barraspalding
 Share
    • Ok, so we've had some (expensive) problems but nothing critical, thankfully. I get parts from FCP Euro in the states and in this instance I got 4 x genuine BMW cooling lines and 4 x OE quality oil lines (because they had no genuine stock). Well, turns out the OE quality didn't fit and the guys wasted a lot of time with them. Thankfully FCP has lifetime returns but the genuine BMW lines locally were $250 each! They also discovered my drivers side engine mount was totally dead and the replacement mount was $350. This sucks as I almost bought new mounts when I did my FCP order and I would have had both the engine mounts for less than this local one. So, I'm assuming at least another $1500 on top of the existing number. They did reassure me that the new (used) turbos looked good which was my main worry. Car will be ready for Monday pickup.
    • Forgot to add, that excellent economy was on street tyres, normal street alignment, I recall they were Kumho KU31. Current motor, with the silly alignment and tyres would go nowhere near those numbers.
    • And also, as small as the effect may be, the larger exhaust side places a lower restriction on the exhaust flow, even when off boost. When my bigger turbo went on you could hear the difference in the exhaust note at cruise (almost everywhere actually) and fuel consumption went down a little bit.
    • I got better economy after fitting a bigger turbo (when purely highway driving, Sydney to Forster, got down to ~8.3L/100KM), as it takes more throttle and RPM to get on boost.
    • Oops. Sorry mate. It is both excellent to hear and also surprising though. The amount of work required to (effectively manually, not on a production line) build a core vs your low retail price point is why I presumed that you were buying cores. But let's also be clear about what is meant by "build". At your price point I can't see you making cores from billet on a mill, even if CNC, or doing all the machine work on a rough casting. Surely the lumps of metal are sourced more or less ready to go from an Asian supplier, right? Maybe the same with shafts. I mean, you could turn shafts up yourself, but it's pretty slow going for items that are all essentially bulk order producable. I was always perfectly willing to believe that you assemble your wheels to shafts, fit up bearings and do all the balancing. I actually expected that you would have been doing all that even if the core did arrive from a supplier with most of that pre-assembled. Nevertheless, please accept my apology.
