R33 GTSt 5spd NSW
For sale
1994 R33 GTSt
Chassis has 255,000km
Motor has 135,000km
Mods:
3" HKS super drager exhaust
3" custom dump
Modified exhaust mani for ewg
4" intake
Hypergear ATR45SS turbo
Splitfire coilpacks
Nistune Z32 ecu
Z32 MAF
Clean injection top feed fuel rail
875cc injectors
Trust return flow intercooler
Hks evc4
Exedy hd clutch
Bad points:
Body is extremely bad, needs a complete respray as clear/paint is pealing.
Tps has an intermittent issue at idle(jumps to .7v on its own).
Interior isn't that great.
Good points:
Timing belt, idlers, tensioners and water pump replaced 5000km ago.
Windscreen replaced 1 year ago.
Good platform for more power, all it needs is a retune on E85 and itd do 300+rwkw without any issue.
Brand new battery.
Registered till 28th of October 2019.
$6500 FIRM.
0405691220
FB_IMG_1551719940537.jpegFB_IMG_1551719949388.jpegFB_IMG_1551719975301.jpeg20190305_043812.jpeg
 Share
    • Did a little bit this afternoon and pulled the dump and turbo off so I could take the mani off to clean it up and give it a few coats of paint. Wire wheeled what I could get to and then got the sand paper out to get the tight spots. Gave it one coat so far, will do another two tomorrow and see if I can fit it in the oven to bake it for an hour along with the adapter and dbw.  Hoping the exhaust wrap I ordered turns up soon so I can wrap the dump and screamer. Ordered 30M so I'll wrap back as far as I can to help a little with temp next to the box and also the floorpan.
    • Yeah I think overall I’m running the expected power I should be running for now and I’ll just enjoy it for the time being until I get some other parts. Thanks for the advice mate I appreciate it!
    • That's fair enough.  Might be time to just enjoy what you have until you sort the ecu/flex sensor situation. You can pretty much guarantee that you are knock limited and e85 is going to be the solution to more power.
    • He didn’t provide that info to me but I think I’m on standard timing. And no we don’t have e85 on the petrol stations here but it’s widely available here from shops. I’m just planning on getting a better ecu before switching to e85
    • Seems bang on to me , g30-900 will make 900 crank on e85(on paper). Deduct ~25% for 98 and you are at 675 crank. Run that to the wheels and fact you are only running 26psi you end up about your number.  People forget how magic E85 is now that just about everyone is running it.   "Back in the day" you had to be north of 30psi on a 850+hp turbo to get 600 at the wheels on 98.
