Wanted: Base map for rb25det (r33) for an EMS Stinger v4
Hmm I'm going to approach this from the other side... What is the car doing that you don't like or what would you like the car to do that is currently isn't doing (handling wise that is) -
By robbo_rb180 · Posted
New whiteline rubber bushes, maybe some adjustable arms (rubber ends like hard race for road car)no need for Sway bar if correct springs or going to be fine tune for the track. A proper alignment with corner balancing and coilovers with spring rate for the right purpose and setting droop correctly. -
By Dylancskyline · Posted
Hi guys Have a series 1 r33. Recently I took the car out for a drive when I got home it was fine I went to start it later that night and nothing....has full power from battery. Have checked and changed starter...relays are alll goood....looom under front drivers wheel was damage so fixed that. I can turn the key on and all the lights come up but when I GO to crank nothing I can hear the starter winning over there's nothing else I can think off cheaking ..... any help would be great. -
Hi all, other than coil overs - anyone running rear sway bars and other suspension upgrades? what does everyone recommend to improve the car handling? How about control bar upgrades etc. photo from vspec performance. thanks
