MLR's Bogan cruise ship
Booked in at Craigs to get the transmission tuned to suit the new powahs.
From talking to a few different people, and the googles of course, not adjusting the transmission tune after power mods can be a sure-fire way to reduce transmission life.
As it only costs around $500 for the transmission retune it is a no brainer to have it tuned to suit.
51 minutes ago, Ben C34 said:
Ah,  for the motorbike.
K
LOL, sorry, for the confusion
I have added all my vehicular Bogan news into this thread
The slammer kit drops the whole bike about 1.5" and firms up the suspension
Plus the OEM stuff is shite, this is "apparently" a little better
2 hours ago, Dose Pipe Sutututu said:
LOL...
Do you need an Asian to show you how to do a mad skid? I don't see the video of your skid in this thread 😂
Because posting random mad skids on the interwebs has never ended badly for said skidder.....
When I hit the drags I'll attempt to get one of the kids to take a vid
The transmission tune is all sorted
I think I want to put a gilmer rear drive on the back of the blower to make it even more whiney and annoying, speaking of annoying......
Funny story, I was waiting for the Mrs to pick up some takeaway, she overheard a couple outside the shop complaining to their friends about the noisy car in the carpark, she heard the friends say,"WTF, that thing sounds hot, not everyone wants a POS car like yours"
It's the little things that make you smile, and annoying people, I always smile when I annoy people
Sorry, no skid vids
  • Like 3
  • Sad 1
5 hours ago, Dose Pipe Sutututu said:
You are upsetting many Australia blokes here.
Commo with blower = skids videos
This is the most un-Australian Commodore I know of 😂
Yep will get Pauline Hanson to pay a visit if you get any more un-Australian
  • Haha 2
Gave the engine some new HPR 10 and filter
And, ohhh noooss, the blower is just touching the bonnet liner thingie
Time will tell what cunning plans will ensue, probably somethong like the carbuilder deadener that is under it, just a bit thinner, maybe
In other news, car is awesomeballs
  • Like 1
  • Sad 2
Car drives great in traffic and loves the Hwy
Drove to Braidwood today, averaged about 9.5l/100km with cruise locked at 100 and 110
Sedate city driving is less fuel friendly at about 16l/100km
Car is wicked fun and fast on the roll
Finally installed the new suspension on the bike, lowered the bike about 1.5" each end
The compliance/performance is so much better than the stock suspension, comparing the new stuff to the stock, front was like a sponge, and the rear was like a pogo stick
Yes I have lost some lean angle, but I really rarely scrapped the pegs before anyway, plus I don't really dive into corners because Harley
 Share
    • I'm trying to maintain stock appearance . Hicas is still installed (although has lockout kit) did you retain factory fuel pump hat? If so I assume you used a bulkhead fitting or similar ?  I was also trying to avoid a full re design as it was previously dynoed at 426kw atw with same setup but different pump. Changing return line would also mean having to change ethanol sensor and fpr and possibly fuel rail. Not chasing more power in any way just reliability of the setup
    • I do think it's weird I had it for 2 weeks then the issue came up out of nowhere and progressively got worse. I would've imagined changing everything in the ignition system would've resolved any ignition related misfires but still has the high rpm and idle misfires that seem unchanged. I would've thought if it was fuel related it would happen all the time unless it's the pump losing pressure when it gets hot. If it was the ecu I would think it would do it all of the time.  Something I noticed when I had it all apart was a pretty decent coating of oil in the J pipe coming from the throttle body. The weird thing about that is the pcv that goes to the intake is blocked off. So that has me wondering if the oil is coming from the turbo because that's the only thing that could get oil in there. This thing does sound like it spools like a mofo like I'm a former dsm guy and the only stock turbo I've ever heard spool this loud (to only go up to about 5psi) is on a diesel truck. And the recirculated bov is really loud too I had a TurboXS RFL and this thing is just as loud and being so low on psi seems a little weird. I don't know if any of this is or isn't related but just trying to make sure I'm not leaving any potentially helpful information out.
    • So latest update. I replaced the ignitor with a jspec unit from enjuku. It felt a lot better at first although it is a little bit cooler of a day than it has been. Warming up didn't have as much misfire sputtering as before. Went on a 10m test drive. Felt good, a lot stronger though I was taking it easy on the boost. On the return trip started getting the cutting out at higher rpm again and was getting worse the longer I was driving. Took it easy the rest of the way home. Before turning the car off was getting the normal idle sputtering I was getting before.  So where I'm at now, entire ignition system has been replaced with upgraded components. Plugs still gapped at .8mm. Removed the fuel cap in case it was building too much reverse pressure I'm the tank, didn't help at all. Now I'm still on the same tank of gas the fuel treatment was in, I'm thinking if I can run that out and then refill with fresh 93 maybe  the treatment is too concentrated in some areas but doesn't explain that it only does it once the car is warm. I'm leaning towards fuel pump or injectors but if the injector was clogging I don't think it would make it shut off like it has but then fire right back up like nothing happened. So my current guess would be the pump. Without a fuel pressure guage no way to test or check it while it's running.  So that's kind of where I'm at. Need to start testing fuel components and ecu/wiring but I'm at a loss of what's the next logical step and procedure for testing it.
    • @niZmO_Man thanks for that info, lucky I bought the gktech ones 🤙.
    • Never cheap out on brakes, tyres, suspension. I learnt the hard way at Oran Park lol
