Unsure if this is the right forum to post under..
I'm looking for opinions on whether I would be better to go 20de +T or put a 25 cam into it?
My friends said 25 cam, I personally want a turbo but can't do both due to high compression?
This probably makes no sense. (Sorry) just very confused.
17 minutes ago, JordanRochelle said:
Sorry, 25 cam shaft?
changing the cam to any possible other cam in an RB20 is a total waste of time and effort. Turboing an RB20 is also a waste of time as the result will be disapointing.
Why disappointing? I've seen plenty of 20de+t that go hard... I'm not chasing power or huge numbers. Just something fun
2 hours ago, GTSBoy said:
They only go hard above 5000rpm. Everywhere else they suck.
This ^^^^^
Having previously owned an RB20DET with a few mods and now having a RB25DET NEO
the difference lower down in the rev range is massivley noticeable
Honestly...sell that rolling wreck for whatever you can get for it.
Buy a going RB25.... if you have to.  Otherwise just about any other car will do till you get off your P's.
Reason, adding a cam is a waste of $$$, changing the motor to an RB25 makes more sense, but is a costly and ultimately futile build.
Plus by the time you cut out the rust, redo the window seals, fix up the front end, upgrade the brakes, suspension, and other stuff, you are up for big $$$.  Buying an RB25 with all this stuff done and then setting out to improve it even more will cost much less and also  - in the end - be a better car.  Plus side of a 25 is what you take off can be resold.
The only possible reason for continuing with that RB20 is you are starting with a 'blank canvas', but its 12 months to 3 years of hard yakka getting it done.
I'm in NZ so don't have the issues on Ps etc..
I have all the parts of this body, the body is straight no rust anywhere.. I just want to keep my 20de cause I have it torn down ready for rebuild. I can get a full rebuild kit cheap asf cause my partner works in parts. Could also get a det block too but I'm just not sure.
I don't want to put the 25 cam shaft into it, I'd rather get a det block or a +T but the boys reckon a 25 cam would be better ??‍♀️
so they think an RB25 Cam (assume you are talking inlet only, there are 2? ) in an RB20DE is better than either an RB20DE+T and an RB25DET?
thats potentially the most retarded thing I have read on here in a while. Even with the best camshafts in the world (2 of them) in an RB20DE it is still a heap of shit. even rebuilt.
And just to hit this one again....the difference between the 20 cams and the 25 cams is so small that the time, money and effort spent on the swap would be better spent buying 6" railway spikes to hammer into your own skull.
The boys at the local kindergarten?  Can they tell you how it is different (and I can tell you that as GTSBoy says its SFA) and what difference it will make?
Good on you for resurrecting another Skyline.
Looks like a big project. If you are in for the long haul, and if I were you, I would look at getting the 20det bock, pistons turbo and build it from the bottom to top. I am not too sure that is all the differences. But do your homework and calculate what it is going to cost, then double it. A good 20det screams nicely.
Good luck.
 Share
    • I run 2 x 525 pumps on factory 8mm fuel lines     ... zero issues, staged of course    Your setup should work fine, all you need to do is find the restriction. A good aftermarket fuel regulator is always a good idea too. If it's not your regulator i'd be suspicious of your fuel tank breather and your tank pressurising. Next would be something with the fuel hat. Then blow out the fuel lines.
    • Update time...... Been a crazy busy time and a bit of a change here. Sold my 370z Nismo as wasn't using it much and wanting a 86/brz so wife can have some fun at the track again also to help with funding the s15 build.  As said last time booked a cruise to NZ. The place is great, drank lots of craft beer, eat food and visited some amazing places   The plains of rohan Before we left I finally got an electrician booked and the shed now has power. Been so good being able to use it at night and not running things off a 20m extension lead. Got stuck in last weekend and reorganised it and cleaned up a lot of stuff. A few more things to tidy over time but really good to work on now. There's 13x 10a GPO, 3x 15a GPO, 4 high bay lights and 5 LED batons so will never have an issue seeing or powering tools. 437344198_7178721088892834_15829362501196293_n.mp4   Work has restarted on the s15. Removed the rear cradle so could pull the fuel tank and finish emptying the stale e85 thats now been sitting for almost 4 years 🤮 Cleaned it out and let it dry. Removed the old lift pump and have reinstalled a new lower pressure pierburg pump with all new hose and lowered the pump to get it nice and low in the sump of the tank. Also got a an old diff cover cleaned up, work has a soda blaster so made quick work of it. Going to put a 4.11 ratio diff in with a fresh rebuild thats been reshimmed for now before buying a good diff centre. And had a big change with going back to full time work. Opportunity came up to apply for a race mechanic job so applied and got it, been some big days so far but definitely enjoying it and getting to work on some cool stuff and with some great equipment. Learning a lot on proper car setup and suspension so will be valuable for the s15. I'll be part of the travelling team form next round too. This weekend will get the fuel tank and system in, need to buy a rollover valve and mount that. Get cradle in with the diff and axles then make a shopping list to buy to finish that off then start looking at cooling setup and plan intercooler pipe routing. Work will definitely be slow now on the car but will be to a higher standard.  The 180sx hasn't sold so may be heading out to Morgan Park labour day weekend for a charity event to have some fun been almost 6 months since I've driven it so will be take time to get comfortable again.
    • I'll rent a fuel pressure tester soon and report back.
    • It has a separate fused 10ga wire running from the battery to the relay in the trunk. 10ga on the ground also.
    • Actually I did the fuel pump rewire 2 days after the issues started. Grinded away the paint and grounded it to the chassis behind the right panel in the trunk.
