Is there parts I can buy to bolt up a rb25det engine and box to my 180sx
Sway bar spacer to allow for the 25 sump clearance ( I here u can use a31 sway bay)?
What's the best x member to use
I here i need to change subframe does this mean all suspension parts to ?
What gearbox x member can I use to  bolt up the g box
Does a company make parts to bolt a 25det running gear into the car into the car?
I have a c34 sedan with the rb25det engine and box and 5 stud r200 subframe and diff
A 180sx with drive shaft and diff was sr then ca still have loom track car 4 stud
Surely some one make the parts you need to bolt in these to the 180sx or maybe I have alot of wat I need already dont realy want to have to make something up I have no way to do my slef I have no job lol and want to buy a engine lift and do it my slef or il sell car and look for a sr setup
Use r32/33  engine cross member and mounts for that frame.
Rb25 gearbox cross member requires the mounting to be moved forward (I welded 2 extensions on)
Need custom tailahaft unless using Rb20 box
Radiator can use one for CA18 for correct outlet positions.
Either make your own sway bar spacer or get a whiteline one
Google 'poor man's Rb conversion nissansilvia.com'  a lot of good info
All standard s chassis is retained but can use s14/15 flca and knuckles or buy a conversion kit requiring new bearings
There is almost 20 years worth of info out there that a Google search will give all info
My cars been Rb since 2003 and done both Rb20 to 25 box biggest problem is keeping it cool so use quality radiator and fans with ducting
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
