5 minutes ago, No Crust Racing said:
Yes deck surface can have soft spots, you would ideally check it for hardness (quick/cheap) but these blocks are not as prone to that as others.
Guarantee you the shop will not clean it enough, it's your job to ensure its minty fresh clean as it's your wallet.
Oil filter is not designed to filter that level of debris, oil coolers really cannot be cleaned out properly.
You will want to have the turbo inspected at minimum incase it's already scored and I strongly suggest fitting Inline filter to the feed.
Thanks for that. How can I test it for hardness? I thought generally you would need a gauge for that and theyre fairly expensive?
I'm fine buying a new oil cooler and heater unit, theyre relatively inexpensive. I am close by to a few turbo places like GCG and Precision Turbos who I am happy to get it to them and pay for them to pull apart and clean it our properly, will still be cheaper than a new turbo I imagine, and definitely cheaper than an upgraded one which would require new parts. I'm not after huge power at this point, maybe in a couple years time, but this is just a weekend car for street use. I don't plan on doing any track days, as I barely have spare time for that sort of thing, and want to keep this car for as long as possible. I will look at getting an inline turbo filter.
Should I also upgrade the sump and install oil restrictors while im at it? are they worth it? I was going to get a new N1 oil pump, not sure if those are necessary with keeping a stock oil pump or will serve any advantage?
2 hours ago, GTSBoy said:
No. If there is loose metal, then it will be stuck all over the place. And if/when it shakes loose after the rebuild, it will cause damage to your new stuff. It's not to be contemplated.
I would probably be better off sending the turbo off to one of the local turbo places like GCG or Precision Turbos to get a full clean out. They would definitely be able to do a proper job of it
23 minutes ago, GTSBoy said:
You do realise we're talking about the whole engine being excruiciatingly cleaned out? Not just the turbo? Right?
I did mention in a comment you replied to about getting another bottom end for $2000. Also said in other comments since I will be getting a new oil cooler, heater core, probably new lines, new N1 oil pump
Isn't it going to be cheaper to just grab a complete RB25 from somewhere like Skyline Spares that has a start up warranty?
By the time you've nickel and dimed yourself into oblivion and spent all this time with machine shops and turbo shops, you could have just dropped in another stock long motor?
Then with your car up and running again, you can take your time to strip and build your current motor into something special.
  • Like 1
Good luck finding a complete RB25DET Neo engine
Sorry, I thought you'd circled back around to the rebuild.
The machine shop will do it for you.
As was said, you need to remove all the oil gallery plugs, inc the crank, VVT solenoids/gears etc and clean everything thoroughly top to bottom then clean it again and when you think it's clean, clean it once more. As for upgrades that all depends on the goal, there's a number of basic things you would do with an engine apart if you have access/time/budget.
N1 oil pump not needed for 300kw, oil restrictors and external drain is nice to have.
I would be looking for a complete good engine with a known history and either building this current one on the side slowly or selling it for whatever you can get, and you will still need to be mindful of the turbo, external oil lines etc as bearing material ends up EVERYWHERE.
2k for a known good bottom end and a very thorough clean/service of the head is likely the cheapest/fastest route from where you are right now.
Can you do all this work yourself or is this going to a workshop? As that has an impact on what you do also.
A few months ago now when I was in Sydney for WTA, I visited Skyline Spares, they had RB's in stock. I'd be amazed if they have no long motors now.
Have you spoken to them to confirm they don't have stock?
Edited by Murray_Calavera
He probs doesn't wanna pay the BS wrecker prices.
To be fair, for the prices they are asking ,you would expect them to be testing/proven etc, and I have seen plenty (across various platforms) that are straight up pieces of shit.
Not saying this is the case here, but buyer beware etc.
I don’t have a heap of spare time, running my own fabrication and welding business, so getting a shop to do all the work. I know a little about engine building, but wouldnt trust myself with something to this extent do happy to pay someone to do it properly. So reckon the $2000 bottom end from a blown headgasket engine is the go? Atleast that wont need a full clean out of bearing material
I believe the N1 is the stock oil pump on the Neo engines anyway. Will definitely do restrictors on it and likely the return drain too while im at it
Was going to call them today, but would have thought with alot of stock they would have had that advertised
yeah i think the price for the blown head gasket bottom end is worth it. Just get all new bearings and seals, get the piston and rod health checked out, make sure the bore is definitely all good, and go from there with it. There was a private guy selling a complete RB25DET Neo and had compression test from when it was in the car at 160-165 across al cylinders for $5000 but got snatched up pretty quick
What is the budget, what is the goal, What workshop is actually doing the work for you?
I would define the variables first then start talking with the workshop, they often know of engines/parts around and will have a preferred machinist and can give some quotes so you can make informed decisions, at the moment it seems like you're just throwing ideas around (which is fine) but doesn't move the project forward.
You already have a fresh head, you're only a set of rods/pistons/bolts/studs away from having a bottom end to match it and a motor that's basically brand new. You will be paying for machining and labour either way so that's already spent.
That shouldn't come to 20k.
The budget is whatever to get the car back on the road. I’ve literally owned it for not even 2 months, i just want to enjoy it. I don’t want to do track days, i don’t want to drift it. Its a street car, for me to go on cruises with some friends and enjoy driving it as an R34 has been my dream car since I was a kid and played Need for Speed, and a GTR is out if the budget these days. I don’t want to make monster power, it was making 400hp at the wheels on full boost at one point with the current setup, so would like to get it back to that/close to it, or whatever the tuner recommends as reliable
Im booked in with TME Motorsport near me. They identified the leaking exhaust valve for me in the first place during a check over, but didnt have time to do the work and i threw some other workshops / tuners names to him and I ended up going with Elite Motorsport, who organised the head service and upgrades, once the head was back on they identified the slight engine knock and that it was losing power at peak torque. They didnt have time to do the engine work for over a month so went back to TME, they were happy to take the work on in early March, get the engine out, see whats exactly wrong, and work out what we will do
Edited by LjB123
  • Like 1
That's rough, R34 GT-R was my dream build too so I did a mock up Z Tune build which I loved looking at, but not maintaining.
Honestly, don't cut corners, just put a basic forged build together and know that the car is not being pushed to give you 300kw and there's always room to move if you want to plus it will sell better later.
Buy once, cry once.
That's my 2 cents.
Buy once, cry once.
That's my 2 cents.
Reckon its worth getting the $2000 block to use as a base? Issue i have is if someone buys that block within the next 2 weeks before the engine is taken out to check over, im kind of stuffed trying to find another block if my current block is damaged, or the crank is damaged and needs major machining
What are you gaining from it? You're not going to be re-using rods/pistons and your crank is likely fine with a polish/linish and at worst some different grade bearing shells?
I'm not sure there's 2k of value in it for you? You can always buy it for peace of mind and keep it as a spare/sell if you find out it's not needed.
Offer him $1500 for quick cash sale etc, always low ball.
True. Whats some good pistons to go with? Was looking at Spool Imports
If you are buying new, just get a spool kit, but better yet ask your engine builder what they like to use. I go with CP because my engine builder told me to. I also went Nitto I beams and CA625 rod bolts because my engine builder told me to. Research shows that's a strong rod/piston combo, but that's a 4 cyl trying to make more power than you air aiming for so the HP/L equation is worse.
Have a quick look on marketplace at least, you would be surprised what stuff comes up for dirt cheap.
Edited by No Crust Racing
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
