Hey everyone I recently have been trying to diagnose my rear glass not opening, I recently discovered that the previous owner/owners messed up the wiring real bad and now when ever my vehicle is unlocked my rear glass opener mechanisms has constant power, so whoever wired it up decided to instead fix it they just would remove the metal rod that allows the window to open, so I put the rod back in and now it's just constant power, does anyone know the wiring diagram for the door locks I've been looking a little bit and they are quite confusing, also here's a video of what I'm talking about, I posted it on YouTube so show.
https://www.sau.com.au/forums/topic/486389-stagea-boot-lid-wiring-issue/
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
