guys im obviously going to need to buy a hiflowed cat and an exhaust to put on my car for street use.... but what catback do i buy? As in for what model? Does an S13 catback fit on a cefiro? or an R32 GTST catback?
https://www.sau.com.au/forums/topic/49590-catbacks/
i've been pondering this recently also.
if its straight through cant you just buy a generic high flow like in the for sale section, then just cut the pipe at the place (or disconnect the joins if its got joins there) and put the cat in between em?
With clamps off course so you can replace it when it gets smelly.
Or have I just missed the point totally?
https://www.sau.com.au/forums/topic/49590-catbacks/#findComment-989649
yeah i dont think it is a cat... i got under the car this morning and i dont think its a catback. Thats ok... im going to get a cheapo rear muffler with a silencer and then get some custom piping made up for it... and a hiflow cat of course :rofl:
https://www.sau.com.au/forums/topic/49590-catbacks/#findComment-999388
  • 4 weeks later...
i could harp on for ages but i'll keep it short and sweet.
good news.
S13 catbacks fit to the A31 with slight mods performed at an exhaust centre.
...so i hear.
I have a Cefiro and an S13, and I can't see how it is possible for one to fit the other.. They are THAT different
https://www.sau.com.au/forums/topic/49590-catbacks/#findComment-1029800
    • I had a 1981 ALFA with an electronic speedo sender that would work for months at a time, and also noth work for months at a time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
