The Wasteland - ACT Style
krzysiu
  • 4 weeks later...
  • 4 weeks later...
19 hours ago, Anonymouse said:
lol - that's good
nah seems to have stopped working. Was a gif of the history of the Nissan GTR's
I've  moved on from Blackadder to I.T crowd, who knows whats next...
  • Like 1
  • 1 month later...
  • 1 month later...
80kms in a 60 zone. $409.00 and 3 points. Yep it was me and I have no legal reason for travelling at that speed sir.
I am a supporter of the police and the job they do.
However every now and then you get C#ntstable cranky pants. There is just no need for the shit attitude.
Need to do more regular psych evaluations in my opinion.
It's like I was the guy rooting his misses while he's been on duty.
My Maloo is an Auto, transmission wouldn't change down gears going up a rise under acceleration. Serviced 2 weeks back.
So I gave the loud pedal a push to force the change and low and behold cunstable cranky pants coming up the rise I was going over as it kicked back. Say no more :(
    • swaybar swaybar swaybar swaybar swaybar anyway OP, what is currently in your car, are they factory shocks and sway bar? Any sign anything else has been changed under there over the years? And as Murray said....what are effect you looking to change
    • Congratulations on your find  Did you mean it has 6k miles or was that a typo? Firstly, keep in mind some movement of the shifter is normal...it is a long rod hanging out of a box bolted to the engine. Having said that there are 2 next places to look: 1. Transmission and engine mounts. If these are worn or broken the shifter will move around more. They are reasonably easy to source and replace on a hoist, and possible but uncomfortable to replace car stands 2. On the bottom of the shifter there is a nylon cup that sits over shifter's ball end. If this is worn or broken the shifter will move around more than it should (but will still shift OK). That is a cheap part and requires removal of centre console, rubber shifter hole covers and a circlip in the gearbox shifter hole to remove the shifter. Re maintenance, as with any new import you should change all the fluids including transmission when you get it; never trust the seller and previous owners to have done the right thing. I am pretty sure R34 GTT is the same as earlier big box transmissions, so use any good quality GL4 75w90 trans fluid if it is shifting well (if it is hard to shift due to synchro wear, redline shockproof lightweight will keep it alive a bit longer before rebuild is required)
    • Well considering I have the exact same problem with that as the original one I don't think that the ignitor is the problem. I would imagine that this being such an uncommon problem the possibility of getting a new ignitor that is bad in the same way as the old one has to be very slim. I'll definitely pull everything apart this weekend and check the turbo out. Got quite a bit of things to check out Saturday like fuel pressure and the pcv so I'll report back once I do that.  Thanks everyone for all the replies this is all really helpful
    • Rb's have issues with bottom end starvation, not head starvation. Which either way, you probably wouldn't ever see on a dyno. Strange... What's pump gas for you? Octane rating?
