96 S2 R33 GTS-T
RB25DET
Stock turbo @ 9 psi
Apexi AVC-R electric boost controler
Split fire coilpacks
3.5" HKS Exhaust with high flow dump pipe.
Front mount intercooler
HKS Pod
DYNO was done by old owner.
186.3kw
rb 26 crank
rb26 rods
86.5mm forgies
1.6mm headgasket
gcg highflow with vg30 exhaust housing
600x300 cooler
bosch 040
stock computer n injectors
346.1hp(258kw) at wheels on 15psi
Edited by sweetr33
R33 SII
- stock turbo @ 10 psi
- full exhaust (turbo back)
- pod filter
- walbro 500-600hp fuel pump
- sard 550cc injectors
- power fc
- fmic
= 204.0 rwkw
(ALSO DISCOVERED LATER THAT NIGHT HOLE IN SILCICONE TUBE ON COOLER PIPING)
Edited by YLD-180
r33 gts-t 95 model
Slide Hi flow Turbo running 13psi
Tomei 1.2mm Head Gasket
Greddy Profec B Spec II
FMIC
TRUST zorst
Apexi Power FC
Stock Injectors
232.7rwkw but wastegate actuator was playin up, will give it another shot with Poncams and a new 1 bar actuator
1997 RS4 Stagea RB25DET
(Auto) - 4 Wheel Drive
GCG HIFLOW TURBO
HYBRID FMIC
3" EXHAUST/DUMP/CAT AND 3.5"MUFFLER
WALBRO 500HP INTANK FUEL PUMP
E-BOOST EBC 15PSI
POD FILTER WITH COLD INDUCTION
203 AWKW! (STOCK ECU)
*AFR's Between 12 and 11
Dyno.doc
R33 GTST Skyline - 365rwhp or 278rwkw
G-Max Wheels rear: 18x9.5 with 265’s front: 18x8.5
Tein hight and rebound adjustable suspension
Full 3inch custom exhaust with Magic Cat and twin Mufflers
T70 turbo on X-Force highmount manifold
Turbosmart 48mm Pro-Gate wastegate
100mm think Front Mount Inter Cooler
Blitz blow off valve
Sard fuel pressure Regulator
Sard 550cc injectors
Walbro 500 horsepower fuel pump
Motec Enginge Management System
Exceedy 5 puck clutch
Pod air filter
Oil catch can
Thermo fan
DBA 4000series sloted disks alround with braided lines
Braided fuel-line, blow-by, breather and radiator overflow hoses
New chrome radiator overflow tank
Gates Racing radiator hoses
I took out the unrelated mods to that list. The car was dynoed in Brisbane before I bought her. She is getting forged pistons, rods and cams put into her at the moment. When I dyno her up here again by the end of the year I will post results. Sorry about the bad pic.
R32 GTST Powered by NEO RB25
- Custom built high mount Garret GT35r turbo
- Fully forged engine rebuild with all the good shit
- Standard Injectors and GTR fuel pump (for the run in)
- Microtech MT8 ECU
- Optimax 98 ron
Pulled close to 200rwkw's on 3psi of boost
*will post dyno sheet when it is made available to me.
Edited by FSTR32
Completely stock motor internally
T04r
sheetmetal intake
custom header
SDS EFI
20 psi on 93 octane
489 rwhp (364 rwkw) @ 7500 rpm
~11.7:1 a/f
Expecting around 600 rwhp with some good gas and more boost.
JT
Edited by J Taylor
R33 series 2
The last dyno seemed rather out (218kw) so I had the car ran again on a different dyno
9PSI
turbo back 3inch
fmic 600*300*75
bp 98
pod
KSP retuned stock ecu
and not the best spark plugs need to be replaced
174.8 @ 6160rpms
rather rich air/on 10.7
R33 series 2
9PSI
turbo back 3inch
fmic 600*300*75
bp 98
pod
174.8 @ 6160rpms
rather rich air/fuel on 10.7
R33 series 2
9PSI
turbo back 3inch
fmic 600*300*75
bp 98
pod
174.8 @ 6160rpms
Let the saga begins:
Sept 2002: 138rwkw
R33 S1 Auto
- 100% stock 7psi
May 2003:155rwkw
R33 S1 Manual
- Auto to manual conversion, std auto 1.43:1 diff retained
- 3" Trust MX Exhaust
- Turbosmart bleed valve 9psi
- Auto ECU (gave weird power dips - ECU still think there is an auto box and allowed for gearshift points)
Jun 2003:155rwkw
- Boost still 9psi (dodgy Turbosmart bleed valve spikes when set higher)
- Std S1 Manual ECU (replacing auto ECU - smoother power curve)
- Apexi panel filter in stock airbox
- Car was having weird problem not wanting to make more power, found out it's dying std fuel pump
Aug 2004:192.8rwkw *shootout*
- HKS EVC EZ-II boost controller 10psi (replacing dodgy Turbosmart bleed valve)
- Apexi SAFC
- ARC FMIC turn-flow style
- Bosch 975 fuel pump (replacing dying std fuel pump)
- Still running std injectors, std turbo
Jun 2005:188.8rwkw - this is not shootout mode, dyno reads a bit lower
- still 10psi boost
- Apexi PowerFC (replacing Apexi SAFC)
- Weird tuning resulted in low kw output, turned out that SAFC was not removed yet (forgot to do as it's hidden in glove box)
Jun 2005:191.9rwkw
- still 10psi boost
- Apexi PowerFC "safe" tune (SAFC is removed so no more "war" between ECUs)
- Still running std injectors, turbo and AFM
Aug 2006: 229.1rwkw *shootout* (Almost 4 yrs since 1st popped its dyno-virgin rear wheels)
- Boost now raised to 16psi on my EVC EZ-II
- HKS GT2535 0.65 A/R turbo (replacing std turbo)
- Z32 AFM (replacing maxed out std AFM @ 206rwkw)
- Still running std injectors, fuel pressure reg, stock airbox with Apexi panel filter
- Apexi PowerFC tuned by a MOTEC experienced tuner @ Chasers
- New set of NGK spark plugs, gapped at +/- 0.7mm (replacing the old OWS plugs)
Future: ???rwkw
- Recommended by tuner to replace std coils with Splitfire coils to give more consistent spark
- Perhaps raise the boost another few clicks after new coils are fitted
OH, and I forgot to mention - All those tunes above are done on Optimax 98. I may have once or twice switched to BP Ultimate or Mobil Synergy9000, but 95% of the times are on Optimax.
My mates series1 R33 GTSt stock with
- full exhaust bar stock dump pipe
- 600x300x75 FMIC
- K&N POD
- Earthed solinoid mod (constant 7-8PSI)
Pulled 220rwhp or 164rwkw flat off the rollers with BP Ultimate
Not too bad i thought anyway
Edited by Ganador
Series 2 Nissan stagea RS Four S
...mods are
front mount
split dump/engine pipe
catco 5" metal inside cat with 3" cone reducers
blitz NUR spec 3" catback exhaust
walbro fuel pump
power fc
K&N panel filter in standard air box
GREDDY FMIC
G.C.G HIGHFLOW TURBO
CUSTOM TURBO BACK EXHAUST
APEXi POWER FC
GREDDY EBC
BLITZ BOV
TOMEI FUEL PUMP
SARD FPR
Z32 AFM
CUSCO CATCH CAN
made 327 rwhp on 17psi
gettin injectors in when turbo is back
and then retune
see what i make
need to scan dyno graph
but 93 gtst
standard internals
standard turbo
standard pump and injectors
blitz ehaust decatted
blitz cooler
splitfire coils
link ecu
211kw @ 9psi of turbo smart bleed valve
R33 S2 GTS-t: Power FC, HKS 2530kai turbo, Pod filter with cai, Z32 afm, 1.1bar (16lb) boost controlled by Blitz DSBC Spec R controller, HKS fmic, GTR bov, Bosch 040 pump, Sard fpr, Nismo 555cc injectors, Splitfire coils, split front/dump pipe, highflow cat, 3inch cat back exhaust. 218rwkw.
20/12/06 Re-tune: 244.9rwkw at 16lb. 200kw by 4300rpm. No power gain beyond 6000rpm.
Edited by maxr33
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
