What do you think about reverse flow FMIC piping on GTST's
What I mean is to come out of the turbo, across the top of the radiator down thru RH inner guard, thru intercooler and return thru LH inner guard using the factory intercooler hole and up to the engine crossover pipe.
The advantage is less heat soak to the intercooler pipng from the intercooler to engine. This will end up having the same amount of heat soak to the piping as the factory piping did
https://www.sau.com.au/forums/topic/58589-reverse-flow-fmic-piping-on-gtsts/
sounds like a good idea, no idea on the thermodynamics flow side of it. you would also have lesss bends before the input side as normally you need about 2 or 3 wide bends to get back to the plenum, whereas you only have 1 main bend which is from the outlet side to plenum inlet side, as the rest are just soft curves
i had my piping setup this way, works well and the pipe from the cooler to plenum doesn't get that hot.
this way you can also keep the pipe diameter 3" from the cooler outlet to the intake plenum if you want.
pic here
  • 1 month later...
  • 11 months later...
Mine is setup so that it uses the stock piping route.
The hot air comes out of the turbo down in to the front bumper via the stock piping route, it then runs below and slightly behind the FMIC which then does 2 90 degree bends in to the FMIC (drivers side), the tank has the inlet positioned in the center of the core.
The cool air then travels out of the fmic via a very short route back in to the stock piping and thats it :P
Touching the turbo out piping, its damn hot almost too hot to touch. :S
The turbo is pushed to its limits BUT the fmic is definitely doing its job as you can feel the inlet side tank being hot then over the core it gradually becomes cold to touch, the outlet tank and piping is cold, apart from the engine cross over pipe obviously.
Both methods have exactly the same amount of 90 degree bends so they should flow exactly the same, the across the engine bay does have a slightly shorter turbo outlet distance.
Hope that makes sense.. I was up at 3am this morning. :S
Edited by Cubes
i have a fairly cheap FMIC kit and the piping that come from the cooler to the inlet manifold gets hots i was just wondering if heat wrap would help? i know most ppl say it keeps heat in not out but there shouldn't be any heat in the pipes so instead it will just stop heat getting in. The outlet side of the FMIC feels nice and cold after a drive but that pipe gets hot
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
