Ok, I lied about the prize but you'll have my admiration for your knowledge...
I'm wondering what the little beige coloured box slung underneath the big gray box is. It's on the right side of the boot. The big gray one would be the HICAS controller I think? So the little beige one would be...(fill in blank:))
Hoping it's A-LSD...I've never seen a "slip" light go on but I don't nail the car that hard around turns and only had it for two weeks. There are 15 lights in the dash and never seen any of them come on except the ones at startup etc. (so handbrake, HICAS, ABS, oil, overdrive, airbag, engine - don't think I've seen any others)
Is there a part number on it?
/edit: it could be ABS controller - my brother's 32 has ABS and HICAS and it's two boxes. I don't have ABS on my 33 and I just have the HICAS box.
Q2: Do you have Active-LSD? It consists of two lights right in the middle of the tacho; "A-LSD" and "SLIP."
Hmm no there's no lights in the tacho itself :D But it's an auto so the tacho is prolly different? There's two groupings of 5 lights each on either side of the dials, plus various other lights scattered around but most of the lights have never come on and when they're not on they're completely black I can't see what they are.
Well what made me wonder is in another post someone suggested that in the model code for R33 if the 18th letter (factory options) is 'C' (which mine is) that means it has ALSD and ABS. I haven't seen this confirmed anywhere else though or anywhere to decode it...it definitely has ABS anyway.
The TOMEI HICAS locks are much smaller that that, and they are usually a small black plastic box, not metal. And I dare say that if it was a HKS one it'd be stamped with HKS all over it - you know how they love to stamp their stuff..
Have a look at the mounting brackets on the box, looks very factory to me.
J
EDIT: Just put the car into HICAS diagnostic mode and the HICAS works fine...rear wheels were doing their little turns etc
Hmm I dunno what HICAS feels like or if it's engaging...I do get a HICAS light when I start the car tho, would I still get that if the HICAS was disengaged?
I just have to know....it's eating me up.
What intrigues me most is it appears some skylines have "mystery-boxes" and some don't - factory option? Or have some original/previous owners removed their mystery-boxes for some reason??
Someone's gotta know...it's probably something incredibly mundane
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
