this is my cold air intake on the stock airbox.
Basically I just removed the stock snorkel and replaced it with a 50mm flex pipe. (I have a lot spare if anyone's interested). Took me about 30 minutes or so.
very similar to my setup, except i attached the end of a funnel to the pipe that sits down next to the intercooler hose!
next step is probably that on my car...
Anybody have any ideas of whether its a good idea to block off the stock entry, or keeping that as well as a secondary?? I am thinking of cutting a circle (proper circle this time :thumbsup:) in the bottom of box, and running hose through the old intercooler piping hole to front bar. But not sure whether I should leave, or block off the front (stock) hole.
Will one "port of entry" so to speak result in more air getting sucked into the box? or will 2x holes result in more flow?
Anybody have any ideas of whether its a good idea to block off the stock entry, or keeping that as well as a secondary?? I am thinking of cutting a circle  (proper circle this time :P) in the bottom of box, and running hose through the old intercooler piping hole to front bar. But not sure whether I should leave, or block off the front (stock) hole.
ha ha you EXACTLY described my steup!
http://www.skylinesaustralia.com/fo...ight=r32+airbox
i cut open the stock hole as a secondary entry
then i cut a hole in the bottom of the stock box and ran a pipe up the stock intercooler holes into this hole and attached it there with cable ties and sealed it off with silicone
then i attached the other end for ram air and put the funnel on it
I will be glad to show you, gordon if you are up in brisbane one weekend...
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
