I need some help urgently, i recently raced my car at Calder park raceway, on the start line i brought my revs up and dumped the clutch, it made a couple of crunches but the car was still accelerating so i kept my foot into it, not knowing that i had just smashed the rear diff caseing in about 10 peices, just wondering if any other GTR owners have had a similar problem and if so how to fix it. We have had the car up on a hoist but we are still scratching our heads on why it has done this, no the car isnt to low its only 1-2 inches lower than standard. it has nismo shocks (non adjustable) AND whiteline springs, any help would be great. cheers
https://www.sau.com.au/forums/topic/74643-problems-with-gtr32-rear-end/
yeah my thoughts also. i usually jack my 32 GTR up by the rear subframe mount points. gtr is a heavy car and I would think putting all that weight on an alloy diff cover would not be good.
nope if i need to see under the car i put it on the hoist, i was thinking maybe the bushes need replacing with some whiteline pinapples.
Hi SLK-GTR, Whiteline pineaples are supplementary, they don't replace the standard bushes.
Things to check;
1. How low is it? Under 355 mm (centre of wheel to guard) is too low and the drive shaft angles torque the diff and the sub frame.
2. Tailshaft alignment and balance
3. Rear and centre tailshaft bearing and carrier
4. Inner CV's
5. Driveshaft alignment and balance
6. Rear wheel bearings
7. Does it axle tramp? Time for some decent shocks?
8. Rear subframe alignment, worn bushes or accident damage
9. Diff centre alignment, bearings and pinion preload
After that it gets a bit more obscure and unlikely.:P
Things to check;
4. Inner CV's
9. Diff centre alignment, pinion preload and bearings
i have checked most of these things, it use to bang with standard height springs in it now that i have lowered it it seems to have made it better, but then i added more power and that caused it to hit the floor harder. it did tramp a little bit but i was spinning to tyres hard when i raced it. all the bearings seam fine there not noisy and it doesnt viabrate under acceleration and de-acceleration. havnrt checked the cv's yet but i did notice the cv boot was broken could be that, the car has not been in any ac cident every thing is fully alligned. thanks heaps on your information very appreciated
cheers dude
Things to check;
4. Inner CV's
After that it gets a bit more obscure and unlikely.:(
it sure is an 89, i think its just one of those things that rarely happen but this shit always with e, i guess im cursed. let us know how u go at wsid and goodluck hopw u dont leave your diff bitts from start to finish.
is this an 89?
I plan on going to WSID with mine on the 29/6 so hopefully I don't suffer the same fate
anyone else been to the drags with there GTR yet?
mark
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
