After studying :confused: (yeah right) RB engines for a little while, i noticed a couple of years back, twin turbo RB25's were kinda popular, especially in VL's. So I was wondering if any of you intelligent humans know if the standard GTR manifold can fit the RB25, or is custom the only way to go? Any help would be greatly appreciated, cheers
The inlet and exhaust manifold stud patterns wers made deliberately different by Nissan to stop people from putting R26 manifolds on RB25's. They believed it would increase the exclusivity of the GTR and support its higher price.:rofl:
Gee that only leaves 100000 other parts that will fit :(
By far, most of the parts that give the RB26 the extra performance are not interchangeable. Things like cams, valves, valve springs, followers, injectors, inlet manifold exhaust manilfold, inlet plenum, throttle bodies, turbos, dumps, engine pipes, inlet air temp sensor, ECU etc
Sure I can use the same spark plugs, oil filter, CAS, water temp sensor etc but they are hardly what I would class as "performance" increasers.
:rofl:
I fitted the twin turbos off the R34 GTR to my GTS25t track car. The manifolds fit after cutting and welding 2 of the flanges, then match porting. Everything then just bolts up like the exhaust. It's not easy or cheap.
Hi Gtr Geoff,
Just interested in how well the GTS25t went and what sort of power it made?
Did you use standard gtr turbos?
Cheers!
A lot of people look into this idea . SK costed out the cams buckets springs etc to mod a R33 25 head , buying the GTR head and manifolds is far cheaper .
I'm not disputing that Nissan made it difficult to fit GTR manifolds to any other RB head , but when comparing them too many things get in the way to make it practical . Obviously the RB20 pattern came first and the GTR type later . It looks impossible to fit the GTR inlet on the alternate pattern because there would be no access to the fasteners . The exhaust stud pattern has the same dramas for the same reason . The two flanges would have been changed to give access to the nuts and washers around the twin turbos .
Bang for buck using the complete RB26 top end (turbo/s optional) is best from a performance viewpoint if you can afford it . Being non VVT it solves the oil drain problems as well and another reason why I bought mine .
Cheers A .
It was feeling nice.
Unfortunately the stock (see ceramic turbines) front turbo decided to let go at 5psi and I now have 25psi compression on 1,2,3. This is appearing more common than I initially thought possible, but when the ceramic turbine let go on this setup (RB26 style) it is often ingested back into the 3 cylinders and scores the bores and stops the valves closing.
I would never do this again with the stock GTR turbos as they tend to be more prone to failure after being removed. That said, it would be too expensive to bugger with using expensive turbos. I think I will be dropping in a complete RB26 for a number of reasons, although they aren't as punchy low in the rev range.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
