  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I will prolly pop in an see you lot on sunday... Hey guess what i am fiddling at putting in fog lamps (cant find a spot to mount them!) And i must of accidently blew the tail light fuse or something. Fiddled and check the fuse box int he driver side, then the Bonnet, Then found on in the boot. The funny thing is now i have a headlight warning beeper!!! It never worked before! Also beeps if keys are in ignition and door is open. I am the champ.
Spose no one wants to trade some Halogen fog lamps for some smaller ones. They just wont fit. Gonna be a lot of dodgey work/hassle.
i used to have my N64 connected to it but that was thru the Antenna switch (RF switch) if you've got all the red,white,yellow wires then it has to be connected thru the video player me thinks :confused:
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
