I'm movng house and I have a lot of car parts I would like to clear ASAP. Please give me an offer, willing to negotiat especially on the standard parts. I have posted this in two parts due to the limit of image links per post.
I am located on the mornington peninsula in Victoria and can also do pickup from my work in Richmond. The following are parts left over after upgrading. Contact me via PM or email at hal (at) write.to
iPod connector and cigarette lighter adapter
- Gives line out and charges ipod
- $25
Apexi Filter - Used
- Used for a few months before swapping to ARC intake box
- Comes with mounting adapter
- $100
R33 Rear Pods
- Fibreglass, good condition, need to be painted etc.
- $150
Stinger Fuse and connector
- As bought from JB Hifi
- $25
Carpet
- Bought from bunnings, matches boot interior pretty well
- About 2m
- $10
Edited by halz
https://www.sau.com.au/forums/topic/95530-moving-house-sale-lots-of-parts/
Standard AFM
- Removed due to upgrade, no problems
- $50
Standard Boost Actuator
- Working fine, removed due to upgrade
- $20
Standard Cam gear
- Working fine, was replaced with apexi cam gear
- $20
Standard caster rods
- $50
Standard Heat Shields
- Exhaust Manifold and standard turbo
- $25
Standard Intercooler
- Removed due to upgrade, only comes with what shown
- $50
Standard R33 Series 2 ECU
- $100
Standard Plenum
- Missing a few hose connectors, but okay besides that
- $50
Standard Turbo
- Started to whine before upgrade, still boosting okay, suit rebuild
- Ended up with two oil lines, one water line has been cut etc.
- $200
Standard Throttle
- TPS sold
- Few scratches on the inside
- $50
Turbo bits
- Water lines from Apexi turbo
- Turbo to intake piping (2" to 2.5" from memoy)
Edited by halz
Interested in the Cusco catchcan, Nismo fuel pressure regulator, Apexi air filter, and the carpet. Would you ship to Sydney? How much for all including Shipping?
Regards
I have also found these parts (I think thats it!!):
- brand new pod filter, never used, code 500 A022 for Z32 AFM (shares some common stud pattern with my used one) - missing the box but comes with instructions - $120
- unused (packaging a bit damaged) HKS Turbo timer harness - 4103-RT001 - for Toyota - $15
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
