I have a 95 r33 gtst...
Its had a shitty idle for quite a while. Ive attached a link to an excel sheet with a datalog from the nissan datascan software.
It shows a warm start, idling for a moment, then easy acceleration to 100km/h.
I would really appreciate it if I could get some opinions on it. The only thing I notice is the very very unstable timing at idle.... but what on earth could be causing this??
Thanks in advance.
Datalog
https://www.sau.com.au/forums/topic/97689-check-out-my-datalog-please/
Is the value of AF Base the learned AF correction? In which case it is quite lean. Check the O2 sensor grounds and its bias with chassis and ECU ground. Also maybe a noisy crank signal. Try running another ground to the CAS. If this dosn't work try one from another car.
  • 4 weeks later...
Ok, swap tested the CAS.... same deal. WHY!?
Not the AFM, O2 sensor, plugs, coils, battery, CAS, AAC valve. I tested the A/F ratios with a wideband O2 sensor & they were spot on too.
I got a shit idle, no power, and my ignition timing is all over the shop.
I'm gonna drive the f**ker off a cliff!!!!
The pfc uses ign in an attempt to lower idle in conjunction with the AAC.
This is what it looks like it is trying to do.
Whats your base idle set to in the pfc?
I would disconnect the aac and reset your idle when warm to as close but ensure its not over the pfc's set idle a/c off. Reconnect the aac.
Init the pfc, load in your maps, start the car and send it through the 30min idle learn. For the next few days it will still occasionally play up, let it do its thing then all of a sudden you will think.. oh shiet its idling perfectly smooth.
DO NOT attempt to change the idle rpm as it will bugger it up and you will constantly have a crap idle from then on. For some silly reason I've always had to init the pfc for it to relearn the idle properly.
If this doesn't work ensure your aac is clean from gum (remove and pull apart, soak and clean) Also ensure the solanoid is working. Hitting the A/C button is an easy way to test, idle should raise, same with turning your power steer.
I would then attempt swapping of the cas and all the other harder and more expensive solutions. :nyaanyaa:
Edited by Cubes
mate, i cant set a base idle.... doesnt matter how i adjust the cas, the timing will jump everywhere at idle. I have tested my datascan cable & software on another r33 & got a rock solid 15 degrees...
plug gap is .8
cubes, i actually have a pfc by the way... havnt had it tuned yet coz i wanna sort this shit out first... but i CANT!
Edited by Mickroy
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
