tem: 1995 Nissan Skyline R33 GTS-t
Website: http://www.skylinesaustralia.com/forums/in...howtopic=109628
Item Condition: Great
Reason for Selling: Looking to downgrade, need cash
Price and Payment Conditions: ANY OFFER OVER $17,000 WILL NOT BE REFUSED!!!
Extra Info:
Engine:
-Highflowed standard r33 turbo
-3"dump pipe into high flow cat, 3 1/2" cat back HKS exhaust into X-Force Cannon w/ 5" tip
-Apexi electronic boost controller
-Hybrid front mount intercooler kit w/ 600mm/300mm/76mm intercooler core
-Wolf 3d fully tuneable aftermarket ECU with hand controller
-Simota airpod filter
-Iridium Spark Plugs
-GTR fuel pump
Driveline:
-Standard 5 sp box with heavy duty clutch
Body:
-Modified front bar with centre section cut out to fit intercooler, and repainted
-Series 2 rear wing
-nismo decals under side repeaters
-HKS decal on boot
Brakes/Suspension/wheels:
-Standard r33 calipers and rotors
-Bendix ultimate pads
-HSD fully adjustable coilovers with height/dampner/camber control
-19" 5 spoke shadow chrome wheels, with polished dish
-235/35/19 nankang front tyres, 235/35/19 marshall rear tyres
Interior:
-Apexi AVC-r controller dash mounted, can give guage readouts for speed, boost, revs, duty cycle etc
-Wolf 3d hand controller
-Dash repainted in white same colour as the car
-all seats and trim standard r33 gear
-genuine momo alloy gear knob
Stereo:
-Sony CD headunit
-Kenwood KFC-M7145IE 500W 7x10's Front Speakers custom mounted in the doors
-Kenwood KFC-M7145IE 500W 7x10's Rear Speakers fitted in custom parcell shelf
Has all the standard features of the gtst including power windows/mirrors, climate controlled air conditioning (18-30 degree range) drivers airbag, leather wrapped steering wheel and gear boot
- Made 300hp/230kW atw on 1.1bar boost (16psi)
- Serviced every 5000km/s with synthetic oil etc
- Mainly ran on standard boost (7-8psi)
-Had approx $20,000+ spent on it, and most mods done within the last 18 months
Any q's give us a txt or call on 0407217325
Pictures: Clicky
Contact Details: 0407217325 or 0265834374
Edited by Satanic_R33
https://www.sau.com.au/forums/topic/109628-sold/
  • Replies 62
price neg,
willing to swap for anything 5k-$15,000 plus cash, let me know wat u got, open to anything
Just had Castrol Fully Synthetic Oil change/filter, iridium spark plugs and fuel filter done over the weekend
https://www.sau.com.au/forums/topic/109628-sold/#findComment-2110720
i got a candy red honda integra 95 model vtir selling at 16500 ONO... i havent got cash to give u as ur cars for sale at $20500... if u want work out something with taking a few extras off ur car and get back to me if ur interested for a straight swap..... if i did have the cash i woulda considered something but as i am after something around my price range for a swap.. cant find no one.. :D Good luck with the sale neway if ur not interested
https://www.sau.com.au/forums/topic/109628-sold/#findComment-2173403
Firstly nice ride hey :D Mate I've got an R32 GTS-T was looking for around $15K. Pretty stock, cooler, 3inch turbo back exhaust, 18 inch tyres, Alpine stereo,painted interior, will have fresh respray soon. Goes really well, regular oil changes. Rego till September. Not sure about cash aswell but its on the table anyway.
Cheers
https://www.sau.com.au/forums/topic/109628-sold/#findComment-2194855
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
