Item: 1970 Datsun 1200 CA18DE Unfinished Project
Item Condition: The car is in reasonable condition for its age, the undercarraige is very good with only a small spot of rust around the accelerator pedal, the body has a little rust around the usual places (rear guards and such), it has small dents nothing major.
Engine is in good condition with only 36000km on the odometer when it was removed from the silvia it was in
Reason for Selling: need the money.
Price and Payment Conditions: $2000neg
Extra Info:
5spd Manual (s3 TRX bluebird).
Custom engine cross member and gearbox Cross member and mounts to suit CA18.
Battery moved to boot.
5x 4 spoke dragways.
Exa radiator + Twin thermos and mounts.
Stanza struts with DBA slotted rotor upgrade but no callipers.
larger swaybar (22mm not 19mm).
VLturbo fuel pump.
Datsun 1200 Ute diff.
Sound deadener removed.
All glass and rubbers.
All interior trim is there except carpet although they are not in the best condition.
Most chrome in ok condition.
Any questions please call 0401165572
for pics please post your email.
thanks.
  • 1 month later...
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
