now for the sale, i have the following on offer.
1) 2 x s15 rear bars ADM in very good nick (black and blue)... $80 each ono
2) S15 rear rear cradle wercking...
-camber arms $150 pair
-lower control arms $180 pair
-other "arms"... make me offers
-or the whole cradle minus diff, driveshafts and hubs $500
3) s15 door tirms in perfect condition... $250 each or $450 pair nego
4) s15 passengers side door shell in blue... $250 in very very good condition
5) s15 mirrors in blue... $100 the pair in excellent condition
6) s15 drivers airbag.. $200.. passengers.. $200... control module $250... or all together $550
7) s15 engine mounts... $50 each or $90 the pair
7.5) s15 clutch standard item with plenty of meat left (flywheel included) $200
8) cefiro seats front and back... very rare colour kinda greyish brownish.. cef owners should know what im talkin about... in excellent condition... $250
9) cefiro crossmember will bolt any rb engine into a silvia complete with engine mounts... $250
10) cefiro stock front and rear bars in good condition in silver... $100 each
11) rb20e engine in very good condition... free (pickup)
12) rb20 gearbox either de or det not sure in very good condition with flywheel and clutch $400
13) Rb20 tailshaft yoke only... $50
13.5) cefiro steering rack non hicas... $200
13.6) cefiro tierods $100 pair
14) s14 crossmember... $200
15) s14 steering rack.. $200
16) s14 tierods... $100 pair
17) S13 side skirts $50
18) SR20det inlet manifold complete with injectores and throttle body $100
19) SR20de complete engine great condition low km's $200
20) s13 standard rear camber arms $40 pair
21) s13 standard rear toe arms $40 pair
22) s15 air con compressor like new $100
23) CA standard intercooler $40
24) s13 standard rear bar two tone silver $80
Aftermarket parts
1) work meisters 18x9.5 (+38) 18x11 (+41) with "drift spec" rear tyres and semi decent front ones in gold.. (has some gutter rash)... $2300 ono
2) HKS camp system.. display vehicle revs.. speed... etc anything from the ecu on your tv screen (not included).. comes with HKS remote.. ... $300
3) greddy emanage with main harness... $350
4) s13 ganador mirrors one side come apart... suit diy fibreglasser... $130
5) tomei exhaust temp gauge black face... $60
6) greddy oil/water temp gauge... electronic.. needs sender... black face... $100
7) s13 apexi mild steel 3" catback exhaust including resonator but not the muffler... $150
theres prolly somemore stuff i forgot to mention but ill post them up as soon as i find any new stuff.
ALL PRICES ARE NEGOTIABLE!!!!!!!!!!!!!!
do not hesitate to contact me via pm or on 0416734388
kinda regards
https://www.sau.com.au/forums/topic/127133-various-nissan-parts-a31s13s14s15/
  • 1 month later...
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
