Hey there,
I own an R32 GTR and was wondering if anyone could help me with this problem. I bought my car up in Queensland, the 4WD light came on, I freaked out and took it around town trying to find someone who could tell me what was going on. I went to see some guru, who ended up being very helpful, (if you're out there Theo, thanks you helped me get back to Canberra so I owe you). Anyway he explained how there was a place to put transmission fluid in the boot, I replaced the transmission fluid, the light went off and I went on my merry way.
The car went fine until today the light came back on. The car is still running quite well. There are a few things that I am concerned about though.
- There is some kind of leak, it's not much but it's there I don't know if it's transmission fluid or not, seems to be coming from rear diff. Is that a cracked transfer case?
- The container that takes the transmission fluid wont fill up. I've filled up the section that I have access to, but it doesn't seem to get all the way to the bottom where it's needed so there is a bubble, is that important?
- Light is still on, so am I just making it worse?
I don't know shit about four wheel drive systems, so if anyone can explain what I'm dealing with that would be great. Also where in Canberra knows about GTR's?
Cheers. :)
https://www.sau.com.au/forums/topic/134826-4wd-light/
i have a similar problem, ive had my 4wd and the abs light come on regularly and ended up being fluid (probley attesa fluid) leaking on the rear diff and fouling a speed senser.
it sounds bit like your problem, ill be pulling out my diff soon to get it rebuilt and im planing on fixing the leak on the attesa and bleeding the system which looks like a big job :ermm:
https://www.sau.com.au/forums/topic/134826-4wd-light/#findComment-2513374
I went and got it looked at today. The car is definately leaking transmission fluid. It looks like when the clutch got replaced recently, it wasn't done properly, and now the system needs to be flushed because there is a bubble in it. That might explain the light being on, and the gap in the transmission fluid in the boot, it doesn't explain the leak though, I'll know more after Monday.
I hope I don't have to rebuild the diff too.
https://www.sau.com.au/forums/topic/134826-4wd-light/#findComment-2516937
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
