One of only 24 bit cd players
MP3 / WMA Playback MP3 Playback
4 channel RCA Audio out
Sperate Sub RCA Out with sub controll
Built-In Amplifier Power 4 x 40 Watt
Radio FM Presets 20 AM Presets 10
Tuner Type FM / AM
Dimensions Depth 7.25 in.Height 2.28 in. Width 7.41 in.
Selling for $300 ono used for a year RRP well over $1000
SOLD
Pickup sydney Only
Edited by hu5tlr
https://www.sau.com.au/forums/topic/140074-sold/
For 450 u can suck my wang
Tuner Type FM / AM
Selling for $450 ono used for a year RRP well over $1000
Pickup sydney Only
https://www.sau.com.au/forums/topic/140074-sold/#findComment-2614686
  • 4 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
