Wanted: R33 GTSt headlight/indicator switch column (behind steering wheel)
Does anyone have a R33 GTSt headlight/indicator switch column? You know the column behind the steering wheel you turn to switch on headlights and push/pull for highbeams?
Know where I can get one cheap or know anyone wrecking a skyline?
Cheers,
Craig.
