windscreen obriens do windscreens for $335 fully installed (they can come to your place and do it for free), and that has the blue UV strip along the top, which is cheaper than the windscreen without it.
i have a new set of front brake pads that i will sell for an extra $50. they are new and are bendix ultimates. they are worth about $110. i'm pretty sure the rotors are ok, just need to be machined (which should be done whenever new pads are installed). the current pads are probably still legal, but it would depend on how picky the person who did the roadworthy was.
https://www.sau.com.au/forums/topic/150567-sold/#findComment-2816569
come on people, serious offers only. if the car hasn't been sold by the weekend i am going to have to ring car yards to see if any of them will take it, and i know i won't like the price they will give me, but it has to go.
https://www.sau.com.au/forums/topic/150567-sold/#findComment-2832943
would you take 8k and i will settle call me if interested 0404 8093 58
Item: 1995 r33 skyline gts25t type M series 1.5
Item Condition: good
Reason for Selling: getting new car
Price and Payment Conditions: price drop!!! 13500 11000ONO as is (no roadworthy). found another car so i need it gone ASAP, MAKE AN OFFER
currently considering offers. the car has to be gone by the SUNDAY. the highest offer by then (by someone who can pick it up on the weekend) will be taken. Am picking up the new car sunday. It MUST be gone by then!
Extra Info:
manual
white
85xxxkms
rb25det
turbo (stock) running 11psi via turbotech boost controller
273rwhp @11psi
stock ecu
hybrid FMIC
pod filter with alloy CAI box
split dump pipe, 3" front pipe, 3" cat, 3.5" x-force cat back
heavy duty clutch
boost gauge
skyline floor mats
power window, mirrors
stock wheels
lowered
BOMEX style front bar
new spark plugs
remote central locking and imobiliser
turbo timer
clean inside and out.
for roadworthy it needs new front windscreen and brake pads
no swaps please.
Pictures:
Contact Details: marc 0409122787 by either text or call, or PM on here.
https://www.sau.com.au/forums/topic/150567-sold/#findComment-2833792
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
