Hey guys this is a bit off the car topic but i have a few lights which i bought for my house to renovate but im moving to a different house now, they have never been installed brand spanking new.
i have
- 100 downlights i bought for $17 each at that time i will sell for $10 - $12 depending on quantity bought and i have a few crystal fittings and exterior light fittings
https://www.sau.com.au/forums/topic/152786-lights-for-sale/
guys i also have some exterior lighting stuff and other interior lighting, there about $7000 worth of stuff just ask and il let u know if i have it anythingto do with lighting. i bought this stuff in a rush and now im selling house so i really gotta get rid of it for my new house i need cash
https://www.sau.com.au/forums/topic/152786-lights-for-sale/#findComment-2854943
Hey guys for all teh people who have been asking what lights i have left i still got heeeeeeeeeeeeapppsssssssss so ill post the pics here. All the halogen spots are available in 1,2,3,4 light bars and the all in brushed chrome colour and the pendants are as shown any questions let m eknow. Let mw know for prices, i also have downlights in white colour i got about 100 to sell. need these gone soon.
https://www.sau.com.au/forums/topic/152786-lights-for-sale/#findComment-2858625
guys i got 200 more white gimble downlights with transformers and globe cos people have been asking me for it price drop to $11.50 firm and deliver will be paid by buyer. PM me whoever is interested
https://www.sau.com.au/forums/topic/152786-lights-for-sale/#findComment-2879485
alot more lights left guys. goto this website to see wta i got left i got alot of this stuff on this site. All stuff from a housing project that went down the drain
www.prismcrystallighting.com
https://www.sau.com.au/forums/topic/152786-lights-for-sale/#findComment-2898190
